[postgis-users] geocoding failure
Sara Yurman
syurman at spatialfocus.com
Fri Oct 14 11:32:11 PDT 2016
Ok, so here's an update. I found the tiger_data.ga_zip_lookup_base empty.
It seemed to be empty because the tiger.county table was empty. I grepped
the loader script for anything that would have loaded the tiger.county
table and didn't find anything. I regenerated the script to be sure, and
got the same result.
So I filled the tiger.county and tiger_data.ga_zip_lookup_base tables. And
got the same result. Is there something I'm not getting about the loader
script? Here's how I generated my loader:
psql -U postgres -d wafflehouse -A t -c "SELECT
Loader_Generate_Script(ARRAY['GA'],'windows');"
This has to run in a windows vm on my laptop for a variety of reasons. In
any case, the script generated looks plausible and seems to work mostly.
I checked all the FROM clauses in the create script for the geocode_address
function, and believe I have data in all the required tables. I'll keep
after it, but any help would be great.
Thanks,
Sara
Sara Yurman, GISP
Spatial Focus, LLC
Geodata Architects
http://www.spatialfocus.com/
Office: (404) 378-0989
Fax: (404) 806-6257
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161014/d1283102/attachment.html>
