[postgis-users] Problem installing postgis on centos 6.8 desktop + postgresql
P O'Toole P.OToole at uwyo.edu
Wed Oct 26 13:18:40 PDT 2016
>Error: Package: gdal-libs-1.9.2-8.rhel6.x86_64 (pgdg93)
>           Requires: libCharLS.so.1()(64bit)
> You could try using --skip-broken to work around the problem
> You could try running: rpm -Va --nofiles --nodigest
Mike,
I can't address whether this is a packaging issue or not but when I do `rpm -qif /usr/lib64/libCharLS.so.1` it gives me:
Version     : 1.0
Release     : 1.el6
Architecture: x86_64
Install Date: Wed 20 May 2015 10:24:52 AM MDT
Group       : Development/Libraries
License     : BSD
Signature   : RSA/SHA256, Mon 14 Feb 2011 09:15:43 AM MST, Key ID 3b49df2a0608b895
Source RPM  : CharLS-1.0-1.el6.src.rpm
Build Date  : Mon 14 Feb 2011 05:11:40 AM MST
Build Host  : x86-05.phx2.fedoraproject.org
Relocations : (not relocatable)
Packager    : Fedora Project
Vendor      : Fedora Project
URL         : http://charls.codeplex.com/
There's a chance you can add the right Fedora repo and install CharLS from that. I often cruise http://rpm.pbone.net/ to track down stuff I don't have access to natively by searching for the .so-dependency names in question. That usually saves having to compile things from source.
- Patrick O'Toole
Application Developer
Wyoming Natural Diversity Database
UW Berry Biodiversity Conservation Center
Department 3381, 1000 E. University Av.
Laramie, WY 82071
P: 307-766-3018
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of postgis-users-request at lists.osgeo.org
Sent: Wednesday, October 26, 2016 1:00 PM
To: postgis-users at lists.osgeo.org
Subject: postgis-users Digest, Vol 176, Issue 12
Send postgis-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	postgis-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of postgis-users digest..."
Today's Topics:
   1. Problem installing postgis on centos 6.8 desktop +	postgresql
      93 (Mike Frampton)
   2. Deleted Shp/Dbf Records Feedback (Paul Ramsey)
   3. Re: Deleted Shp/Dbf Records Feedback (Komяpa)
Message: 1
Date: Tue, 25 Oct 2016 23:16:12 +0000
To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Problem installing postgis on centos 6.8
	desktop +	postgresql 93
Message-ID:
	<BY2PR01MB16880713147B1ED7833667F387A80 at BY2PR01MB1688.prod.exchangelabs.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi
Im trying to install postgis on to a  centos 6.8 desktop  server which has postgresql 93 and phpPgAdmin installed. Ive followed the instructions at
http://postgis.net/install/
but I keep running into an error related to a missing library ( libCharLS.so.1 ). i.e.
cd /tmp ; rm -rf postgis ; mkdir postgis ; cd postgis
wget https://download.postgresql.org/pub/repos/yum/9.3/redhat/rhel-6-x86_64/pgdg-centos93-9.3-3.noarch.rpm
rpm -ivh pgdg*
yum -y install postgis2_93
This gives an error
--> Processing Dependency: libCharLS.so.1()(64bit) for package: gdal-libs-1.9.2-8.rhel6.x86_64
--> Finished Dependency Resolution
I tried to manually install / reinstall the epel release but that didnt solve the issue.
rpm -e epel-release-6-8.noarch
rpm -ivh  http://dl.fedoraproject.org/pub/epel/6/x86_64/epel-release-6-8.noarch.rpm
Does anyone have any pointers, can anyone provide any suggestions ?
cheers
Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161025/df728153/attachment-0001.html>
Message: 2
Date: Wed, 26 Oct 2016 10:10:17 -0700
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Deleted Shp/Dbf Records Feedback
Message-ID:
	<CACowWR0pz-vNbX-8DXVw_MPGEhQjbRgfjtHK=70t++2f0g7XAQ at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
I'm about to fix this issue
https://trac.osgeo.org/postgis/ticket/3645
but I'm unsure whether to fix it as a "bug", with patches back into stable
releases (2.3, 2.2, etc) or just as a "feature" for upcoming releases.
It'll change behaviour, in that by default files with virtually deleted
records will no longer load the deleted records. (Someone wants a flag to
optionally re-enable the old behaviour, but that's definitely a feature,
not something that would go into a bug fix.)
Anyone have opinions, real-world concerns?
P.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161026/75625954/attachment-0001.html>
Message: 3
Date: Wed, 26 Oct 2016 17:38:51 +0000
Subject: Re: [postgis-users] Deleted Shp/Dbf Records Feedback
Message-ID:
	<CAC8Q8tLL_0Q=UG59Yw6w3YEKWcE0CUroPJi0BBPDUCJ92iDv4Q at mail.gmail.com>
I think, back-patch.
This is definitely a bug, so if someone was relying on this behavior, it's
better to get them fix their data than to say later "we can't go to next
major PostGIS, we rely on this bug being not fixed".
ср, 26 окт. 2016 г. в 20:10, Paul Ramsey <pramsey at cleverelephant.ca>:
> P.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161026/bf87e670/attachment-0001.html>
Subject: Digest Footer
End of postgis-users Digest, Vol 176, Issue 12
