[postgis-users] Line within range of another line?
Regina Obe lr at pcorp.us
Mon Oct 31 13:39:17 PDT 2016
Temiz,
Good question.  They will yield similar results, but not exactly the same
1)      When you do a buffer, it's an approximation since it uses by default 8 segments to approximate a quarter circle.  That said, it's possible you will get a different count of lines than you would with ST_DWithin and the ST_DWithin answer would be more correct.
2)      Unfortunately if you do need to return that portion of your line that intersects your buffer, you would need the ST_Buffer you have and deal with the less the accurateness of it if it's an issue.
3)      Have you compared the performance of both?  Your faultbuffer would not be able to utilize an index on the fault4analyse table, where as the ST_DWithin approach could.
4)      It would also be interesting to compare the performance differences.  In some cases using ST_Intersects with buffer is faster than using ST_Dwithin since GEOS has some special optimizations that I think ST_Dwithin lacks, but ST_DWithin would need to do less work up front than buffer (which could be huge for large geometries) and a buffered geom can't use index of underlying table.
I think when you buffer depending on the size of your buffer and the jagged edges you have in fault, you may end up with a simpler geometry that would require less work for ST_Intersects / ST_Dwihin.
It's also not clear to me why you are doing a ST_Union (do you have multiple fault lines with same gid?  ) if not then that union is not necessary.
And I would think you would want one record per road so the union should be done after, so the below would make more sense.
SELECT road.gid,  ST_Union(ST_Intersection(road.the_geom, ST_Buffer(fault.the_geom, 100)  ) ) as road_fayBuffer
FROM road4analyse as road
INNER JOIN fault4analyse AS fault
  ON ST_DWithin(road.the_geom, fault.geom, 100 )
GROUP BY road.gid
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Ahmet Temiz
Sent: Monday, October 31, 2016 3:59 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Line within range of another line?
Thank you,
It was great help.
Later, I had built this:
WITH faultbuffer as (
   SELECT gid,ST_Union(St_Buffer(the_geom,100)) as geom from fault4analyse group by gid
SELECT road.gid,ST_Intersection(road.the_geom,faultbuffer.geom ) as road_fayBuffer from road4analyse as road , faultbuffer
  WHERE ST_Intersects(road.the_geom, faultbuffer.geom )
and it is reasonably fast.
Does it do same thing you have offered ?
kind regards
On Sun, Oct 30, 2016 at 10:55 AM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Use ST_DWithin  (works for both geography and geometry) and any kind of geometry, not just lines .
My example is for geography since units are always in meters.  For geometry units you have to specify based on your spatial_ref_sys and geometries have to have same spatial ref sys
something like below will return all roads that are within 100 meters of a fault line
SELECT l.gid, l.geog
FROM roads As l
WHERE EXISTS (SELECT 1 FROM fault_lines As fl WHERE ST_DWithin(fl.geog, l.geog, 100) );
If you need to know the exact fault lines, do a JOIN instead – keep in mind if a road is close enough to more than one fault line, it will be duplicated
SELECT l.gid, l.geog, fl.name <http://fl.name> , ST_Distance(l.geog, fl.geog) AS dist
FROM roads AS l INNER JOIN fault_lines AS fl ON (ST_DWithin(fl.geog, l.geog, 100) );
If you want jus the closes fault line within 100 meters use DISTINCT ON
SELECT DISTINCT ON(l.gid)  l.gid, l.geog, fl.name <http://fl.name> , ST_Distance(l.geog, fl.geog) AS dist
ORDER BY l.gid, dist;
Hope that helps,
Regina
http://www.postgis.us
http://www.paragoncorporation.com
http://postgis.net
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Ahmet Temiz
Sent: Sunday, October 30, 2016 2:59 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >; PostGIS Users Discussion <postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net> >
Subject: [postgis-users] Line within range of another line?
How can I find Line within range of another line?
I mean I try to find line section within certain range of another line.
For example, road lines close to fault lines.
Ps : I know that using st_buffer causes performance issue.
Can you give any advice?
Regards
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem  Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
postgis-users mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-users
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161031/b8f9b4a8/attachment.html>
