[postgis-users] pl/pgsql function to write table in parallel mode
Nicolas Ribot
nicolas.ribot at gmail.com
Fri Sep 16 03:32:43 PDT 2016
Playing with new PG9.6rc1 / Pgis 2.3beta1, I found parallel query mode to
be really efficient to process big tables.
Unfortunately, it is not possible to directly create tables with parallel
plan (create table as select...) (see:
https://wiki.postgresql.org/wiki/Parallel_Query).
It is possible, though, to use copy mode with psql feed to create a table
with parallel plan enabled.
To allow creating tables directly in pure SQL script, I developed a small
hack function that takes a SQL query and creates a table from it, using
COPY command with psql PROGRAM executing the query.
Usage:
select * from create_table_parallel(
'table_name',
'select p.id as idparc, c.gid as idcarreau
st_intersection(p.geom, c.geom) as geom
from parcelle_sample2 p
join carreau_sample2 c on st_intersects(p.geom, c.geom)',
'/usr/local/pgsql-9.6/bin/psql -A -t -p 5439 -d nicolas -c',
8, -- workers
true);
Limitations:
• delimiter used for copy operation defaults to '|'
• a 'LIMIT 0' clause is inserted at the end of the passed query to create
table structure: query to run cannot contain a LIMIT clause.
• The function is not safe, as it injects user parameters to build psql
command, and it's not extensively tested.
Perfomance expected:
Depends on the number of workers configured and planned:
On a small dataset (~15 000 pg intersected with 360 000 pg), with 8 workers
configured and 3 choosen by the planner, table creation took *24s vs 1m25s*
with a traditionnal create table as select...
Nicolas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160916/b051b25f/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160916/b051b25f/attachment.obj>
