[postgis-users] Creating an 'editable' view in PostGIS
Matthew Baker
mattbaker at gmail.com
Fri Sep 16 13:36:46 PDT 2016
Hi all,
I've asked this on GIS.SE, to no avail:
I'd like to store label placement properties in a separate table, build
a view of the data I want to use for my map, and use QGIS to move the
labels manually. The idea is when the labels are updated, the placement
coordinates would go into the LABEL_X and LABEL_Y fields in the label
placement table, but the geometry of the underlying points and several
other attributes (coming from the source tables) would remain unchanged.
However, when all is in place, QGIS throws the following error when
trying to save the edits to the view (the edit session can start, labels
moved, but cannot save):
|Could notcommitchanges tolayer schools_district_map
Errors:ERROR:1attribute value change(s)notapplied.Provider
errors:PostGIS error whilechanging attributes:ERROR:infinite recursion
detected inrules forrelation "schools_district_map" |||
Here is the definition of the view :
|CREATEORREPLACE VIEWpublic.schools_district_map
ASSELECTsch.schnum,sch.oid,sch.abbreviation,sch.school_level,sch.geom,l.label_x,l.label_y
FROMtemp_schools_label sch LEFTJOINdistrict_map_labels l ONsch.schnum
=l.schnum;|
And here are the rules I've applied to make the view 'editable':
|--delete rulecreateorreplace
rule"delete_label"asondeletetoschools_district_map do instead
deletefromschools_district_map whereoid =old.oid;--insert
rulecreateorreplace rule"insert_label"asoninserttoschools_district_map
do instead insertintoschools_district_map
(label_x,label_y)values(new.label_x,new.label_y);--update
rulecreateorreplace rule"labels_update"asonUPDATETOschools_district_map
do instead updateschools_district_map setlabel_x =new.label_x ,label_y
=new.label_y whereoid =new.oid;|
QGIS is then set to display the labels using the label_x and label_y field.
I used this post as a guide to build the view, rules:
http://gis.stackexchange.com/questions/88120/how-to-set-posgis-default-sequential-value-in-a-qgis-editable-view
If anyone can spot where I might have left something out, or if there is
a glaring oversight on my part, OR if this is maybe a bad idea... let me
know!
Thank you!!!
-Matt Baker
Denver Public Schools
Denver, CO
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160916/e87946ae/attachment.html>
