[postgis-users] postgis-users Digest, Vol 175, Issue 9
Juha Ylonen
jy.fmdx at gmail.com
Sat Sep 17 08:11:03 PDT 2016
Y
On 16/09/2016 10:01 PM, <postgis-users-request at lists.osgeo.org> wrote:
> Send postgis-users mailing list submissions to
> postgis-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/postgis-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> postgis-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
> 1. what does it really mean for one geometry to be equal to
> another (Rhys A.D. Stewart)
> 2. Re: what does it really mean for one geometry to be equal to
> another (Sandro Santilli)
> 3. Re: what does it really mean for one geometry to be equal to
> another (Paul Norman)
> 4. Re: what does it really mean for one geometry to be equal to
> 5. Re: what does it really mean for one geometry to be equal to
> 6. Re: what does it really mean for one geometry to be equal to
> 7. pl/pgsql function to write table in parallel mode (Nicolas Ribot)
> 8. Re: fuzzy tolerance (Willy-Bas Loos)
> Message: 1
> Date: Thu, 15 Sep 2016 20:53:25 -0500
> From: "Rhys A.D. Stewart" <rhys.stewart at gmail.com>
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: [postgis-users] what does it really mean for one geometry to
> be equal to another
> Message-ID:
> <CACg0vTkjgR1ZhuDsHK1dZOKi=K=RBXbxa+qmq6E46Q0ZurK2=w at mail.
> gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Greetings all,
> I maintain a medium size table of customer locations, which, for business
> purposes now needs to not have any coincident points. Table definition
> follows:
> service.location
> premises text NOT NULL,
> matchtype text,
> matchdate date,
> connectedtransformer text,
> g geometry(Point,3448),
> CONSTRAINT servicelocation_pkey PRIMARY KEY (premises),
> CONSTRAINT servicelocation_premisesnumber_check CHECK
> (char_length(premises) = 6 OR char_length(premises) = 7),
> CONSTRAINT servicelocation_premisesnumber_is_a_number_check CHECK
> (premises !~* '[A-z]+'::text)
> There are approximately 866k rows, and a gist index on g. I update the
> table so that no geometries are coincident ( see
> https://gist.github.com/rhysallister/bcb4bb07a99d69938fff88f150883bee for
> the sql to remove the coincident geoms) I ran the sql in the gist until it
> said 0 rows affected.
> To prevent one from inserting or updating a coincident geometry I try to
> create a unique index on g. Since gist doesn't support unique indices I do:
> CREATE unique INDEX unique_g ON service.location (st_astext(g) );
> ERROR: could not create unique index "unique_g"
> DETAIL: Key (st_astext(g))=(POINT(727895.4 663599.3)) is duplicated.
> This makes me slightly flummoxed. I'm pretty sure the query in the gist
> returned 0 affected rows. But, maybe I missed a step. I try to find the
> offending rows with:
> select premises, st_astext(g), g from service.location
> where st_equals(g, 'SRID=3448;POINT(727895.4 663599.3)'::geometry)
> premises st_astext g
> 267077 POINT(727895.4 663599.3)
> 0101000020780D0000CDCCCCCCAE3626419A9999995E402441
> Strange. I now move to being slightly perturbed. I'm very sure the previous
> error message made mention of duplicity. I then run
> where st_astext(g) = 'POINT(727895.4 663599.3)'
> 267053 POINT(727895.4 663599.3)
> 0101000020780D0000CDCCCCCCAE362641999999995E402441
> Now I'm just confused, the 2 premises have the same st_astext, but
> different wkb representations and as such are not being caught in the
> st_equals call.
> Is there some gotcha that I don't know about, maybe something in the docs
> that I missed or is this not supposed to happen?
> Rhys
> Peace & Love|Live Long & Prosper
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/postgis-users/
> attachments/20160915/313afacc/attachment-0001.html>
> Message: 2
> Date: Fri, 16 Sep 2016 07:11:55 +0200
> From: Sandro Santilli <strk at kbt.io>
> Subject: Re: [postgis-users] what does it really mean for one geometry
> to be equal to another
> Message-ID: <20160916051155.GB4828 at localhost>
> Content-Type: text/plain; charset=us-ascii
> > st_equals call.
> What you describe is expected:
> the text representation is approximated/truncated.
> You could create your index on ST_AsBinary(geometry) if you wanted
> to check binary-level equality, but as your subject asks: what's
> your concept of equality ? Do you really want those practically
> identical points in your db ? Or you could create an index on
> ST_SnapToGrid(geom, <tolerance>), for points to be no closer
> than <tolerance>. Or (for lines) you could use ST_HausdorffDistance.
> Many ways to interpret equality, which is why the equality operator
> is currently just checking for approximated minimum bounding box equality
> (probably still equal for your two almost-identical points).
> --strk;
> () Free GIS & Flash consultant/developer
> /\ https://strk.kbt.io/services.html
> Message: 3
> Date: Thu, 15 Sep 2016 23:19:49 -0700
> From: Paul Norman <penorman at mac.com>
> To: postgis-users at lists.osgeo.org
> Message-ID: <702ce217-2a87-be77-13f1-63bd1a34c5f9 at mac.com>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> > premisesst_astextg
> > 267077POINT(727895.4
> > 663599.3)0101000020780D0000CDCCCCCCAE3626419A9999995E402441
> > 267053POINT(727895.4
> > 663599.3)0101000020780D0000CDCCCCCCAE362641999999995E402441
> > st_equals call.
> > docs that I missed or is this not supposed to happen?
> A safe bet is that you're hitting floating point issues. EWKB is the
> canonical format for geometries, but the conversion to a text
> representation could lose some precision. If you did want to require
> unique geometries, you could do it with a btree index on the geometry,
> not st_astext of the geometry.
> As a general rule, comparing two floating point numbers for equality is
> tricky. What you probably want is an exclusion constraint which prevents
> two points from being within a small distance of each other.
> I don't know of a great way to do this, but a bad way that might work is
> EXCLUDE USING GIST (ST_Buffer(geom, 0.1) WITH &&). See
> https://www.postgresql.org/docs/current/static/rangetypes.html#RANGETYPES-
> CONSTRAINT
> and the links from there. I haven't tested this.
> attachments/20160915/eabff54e/attachment-0001.html>
> Message: 4
> Date: Thu, 15 Sep 2016 23:37:38 -0700
> Message-ID: <9221777f-f4c2-ce2b-e19a-680ce943c9b3 at mac.com>
> Content-Type: text/plain; charset=utf-8; format=flowed
> > is EXCLUDE USING GIST (ST_Buffer(geom, 0.1) WITH &&). See
> rangetypes.html#RANGETYPES-CONSTRAINT
> After further though, this is doing a bounding box comparison so it's
> not quite 0.1 projected units and you can use ST_Expand instead of
> ST_Buffer.
> Message: 5
> Date: Thu, 15 Sep 2016 23:58:28 -0700
> Message-ID: <4ac8f86f-fae3-b5f5-6880-88fe0e5c0ec0 at mac.com>
> > than <tolerance>.
> This won't check that points are no closer than <tolerance>, nor will it
> solve floating point issues. It's the same as rounding. If two points
> are on either side of the line where they round to different grid
> points, even if they are arbitrarily close, up to the limit of precision.
> It does mean that you will see fewer values where you get floating point
> equality issues, but the difference between the rounded floating points
> will increase.
> Message: 6
> Date: Fri, 16 Sep 2016 09:11:50 +0200
> Message-ID: <20160916071150.GA9706 at localhost>
> > geometry, not st_astext of the geometry.
> The btree opclass for geometry only checks bounding box equality,
> not geometry equality (see lwgeom_eq, aka OPERATOR=).
> --strk;
> Message: 7
> Date: Fri, 16 Sep 2016 12:32:43 +0200
> From: Nicolas Ribot <nicolas.ribot at gmail.com>
> Subject: [postgis-users] pl/pgsql function to write table in parallel
> mode
> Message-ID:
> <CAGAwT=2AM14QetUCihrKAr+1+aQ+bdebkYiAYhp9WUtj4i0zpQ at mail.
> gmail.com>
> Hi,
> Playing with new PG9.6rc1 / Pgis 2.3beta1, I found parallel query mode to
> be really efficient to process big tables.
> Unfortunately, it is not possible to directly create tables with parallel
> plan (create table as select...) (see:
> https://wiki.postgresql.org/wiki/Parallel_Query).
> It is possible, though, to use copy mode with psql feed to create a table
> with parallel plan enabled.
> To allow creating tables directly in pure SQL script, I developed a small
> hack function that takes a SQL query and creates a table from it, using
> COPY command with psql PROGRAM executing the query.
> Usage:
> select * from create_table_parallel(
> 'table_name',
> 'select p.id as idparc, c.gid as idcarreau
> st_intersection(p.geom, c.geom) as geom
> from parcelle_sample2 p
> join carreau_sample2 c on st_intersects(p.geom, c.geom)',
> '/usr/local/pgsql-9.6/bin/psql -A -t -p 5439 -d nicolas -c',
> 8, -- workers
> true);
> Limitations:
> • delimiter used for copy operation defaults to '|'
> • a 'LIMIT 0' clause is inserted at the end of the passed query to create
> table structure: query to run cannot contain a LIMIT clause.
> • The function is not safe, as it injects user parameters to build psql
> command, and it's not extensively tested.
> Perfomance expected:
> Depends on the number of workers configured and planned:
> On a small dataset (~15 000 pg intersected with 360 000 pg), with 8 workers
> configured and 3 choosen by the planner, table creation took *24s vs 1m25s*
> with a traditionnal create table as select...
> Nicolas
> attachments/20160916/b051b25f/attachment-0001.html>
> A non-text attachment was scrubbed...
> Type: application/octet-stream
> Desc: not available
> attachments/20160916/b051b25f/attachment-0001.obj>
> Message: 8
> Date: Fri, 16 Sep 2016 17:20:05 +0200
> From: Willy-Bas Loos <willybas at gmail.com>
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>, Daniel
> Baston <dbaston at gmail.com>, Lars Aksel Opsahl <
> Lars.Opsahl at nibio.no>
> Subject: Re: [postgis-users] fuzzy tolerance
> Message-ID:
> <CAHnozTi76La74wU0TXE68YLn9TQPHJUbDMYcyR0hCMruROmkRg at mail.
> gmail.com>
> On Thu, Sep 15, 2016 at 1:58 PM, Daniel Baston <dbaston at gmail.com> wrote:
> > > Any words of warning about using a trigger and storing the data on a 10
> > cm
> > > grid like i suggest?
> Wow, thanks for the great responses. Lars Opsahl, nice to see you in the
> mailing list :D
> So what i gather from this is that it is not ideal to use st_snaptogrid. It
> solves some problems, but it creates some new ones too.
> Maybe a second geometry column would be a better idea, so that the original
> is still there (and will consume your server's memory &hdd space :/ )
> Anyway, there is no automatic way to solve the problem right now.
> So how big are the problems that arise from this?
> For me i have to say that we often have problems with errors in overlays,
> and we have to keep using st_makevalid after every step of a process.
> Decreasing the supersmall artifacts in the geometries would probably help
> with that.
> @Lars Opsahl, you describe a lot of problems or very reasonable wishes in
> your presentation (link to abstract in previous mail). Do you think those
> could be solved with a concept similar to fuzzy tolerance?
> @Daniel Baston could you describe some of the problems that the
> hyperprecise coordinates cause for you?
> Cheers,
> Willy-Bas Loos
> attachments/20160916/5dd0f77f/attachment-0001.html>
> Subject: Digest Footer
> End of postgis-users Digest, Vol 175, Issue 9
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160917/e59597c5/attachment.html>
