[postgis-users] If there any difference for snap to for lines and surfaces in Postgis Topology ?
Lars Aksel Opsahl
Lars.Opsahl at nibio.no
Sun Sep 18 12:20:28 PDT 2016
Hi
First I tested with lines and that worked find, the lines added the second time snapped to first lines. The data I tested with are found at.
https://github.com/NibioOpenSource/pgtopo_update_sql/blob/develop/src/test/sql/import/data3/edge_1219.<https://github.com/NibioOpenSource/pgtopo_update_sql/blob/develop/src/test/sql/import/data3/edge_1219.prj>shp .
At https://trac.osgeo.org/postgis/wiki/UsersWikiPostgisTopology I have added section
called “Convert shape file and simple feature data to Postgis Topology” that has some more info the function topo_help_sf_to_topology_case_1.
Here is the sql I tested with for lines that worked ok.
# create test schema if not exist
psql sl -c'CREATE SCHEMA IF NOT EXISTS test2;'
# copy file muni_buffer_out that contains not ok buffered out municipalitie border "where komid not in (125)" into table test2.sf_in (drop and create if exits)
shp2pgsql -W ISO-8859-1 -d -D -s 4258 data3/edge_1219 test2.sf_in | psql sl; psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_3.muni_surface');"
# copy data from test2.sf_in into table topo_3.muni_surface (append data to topo_3.muni_edge)
psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_3.muni_edge',0.00001);"
# copy file muni_buffer_in that contains not ok buffered in municipalitie border "where komid not in (214)" into table test2.sf_in (drop and create if exits)
shp2pgsql -W ISO-8859-1 -d -D -s 4258 data3/edge_1521 test2.sf_in | psql sl; psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_3.muni_surface');"
Then I tried the same with surface data and they did not snap to as I expected.
The file https://github.com/NibioOpenSource/pgtopo_update_sql/blob/develop/src/test/sql/import/data2/muni_ok.shp contains the ok surfaces, but not the 4 surfaces where I have moved the border data around. But all edges needed are present in this file since the surface not added are inclosed by other surfaces.
The I added the files “muni_buffer_in.shp muni_buffer_in_2.shp muni_buffer_out.shp muni_projected.shp”, my hope was that the edges for this surfaces should snap to the exiting edges, but that did not seem to happen.
Her is the code I tested with
# copy file muni_ok that contains ok municipalities border "where komid not in (125,214,233,301)" into table test2.sf_in (drop and create if exits)
shp2pgsql -W UTF-8 -d -D -s 4258 data2/muni_ok.shp test2.sf_in | psql sl;
# copy data from test2.sf_in into table topo_2.muni_surface (topo table topo_2.muni_surface will craeted on the fly if it does not exist)
psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_2.muni_surface',0.00001,false,'new_gid_id',true,true);"
shp2pgsql -W ISO-8859-1 -d -D -s 4258 data2/muni_buffer_out test2.sf_in | psql sl; psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_2.muni_surface');"
# copy data from test2.sf_in into table topo_2.muni_surface (append data to topo_2.muni_surface)
psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_2.muni_surface',0.00001);"
shp2pgsql -W ISO-8859-1 -d -D -s 4258 data2/muni_buffer_in test2.sf_in | psql sl; psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_2.muni_surface');"
# copy file muni_projected that contains not ok projectes municipalitie border "where komid not in (233)" into table test2.sf_in (drop and create if exits)
shp2pgsql -W ISO-8859-1 -d -D -s 4258 data2/muni_projected test2.sf_in | psql sl; psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_2.muni_surface');"
# copy file muni_buffer_in_2 that contains not ok buffered in municipalitie border "where komid not in (301)" into table test2.sf_in (drop and create if exits)
shp2pgsql -W ISO-8859-1 -d -D -s 4258 data2/muni_buffer_in_2 test2.sf_in | psql sl; psql sl -c "SELECT topo_help_sf_to_topology_case_1('test2.sf_in','topo_2.muni_surface');"
Lars
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160918/49e5437f/attachment.html>
