[postgis-users] PostGIS Out-DB Raster Not Behaving As Expected
Tumasgiu Rossini rossini.t at gmail.com
Tue Apr 11 02:27:22 PDT 2017
could it be that you are trying to tile your rasters with the option -"t
auto" ?
Sorry, I can't test it right now.
2017-04-11 11:07 GMT+02:00 Osahon Oduware <osahon.gis at gmail.com>:
> Hi Regina,
> I have tried the queries above. For the related raster table,
> SELECT r_table_name, r_raster_column, out_db FROM raster_columns; RETURNS
> "raster_table","rast","[False, False, False]"
> SELECT t.rid, (md).isoutdb, (md).path
> FROM nj_ned AS t, ST_BandMetaData(t.rast) AS md
> limit 1; RETURNS
> 1,False,""
> I believe from the result of the 1st query that out-db is not enabled.
> However, the environment variable POSTGIS_ENABLE_OUTDB_RASTERS is SET to
> 1.* I have tried to also enable it with the following, restarted the
> postgres Service, and re-loaded the raster, but the 1st query gives the
> same result:*
> ALTER DATABASE <database_name> SET postgis.enable_outdb_rasters TO True;
> Please, could you help me further on what I am not doing right to enable
> the out-db rasters.
> On Mon, Apr 10, 2017 at 8:31 PM, Regina Obe <lr at pcorp.us> wrote:
>> You should also check the following queries
>> Out_db should be true for all your bands for the specific table and as
>> Jorge mentioned, you shouldn't see any over view tables (which start with
>> o_..{table}.
>> I believe QGIS internally tries to use over view tables to speed things
>> up, so it's possible it's using an overview table instead of the main outdb
>> table if you are zoomed out enough.
>> For outdb, querying the meta data of the raster will tell you the path if
>> it's an outdb.  Replace nj_ned with your table name.
>> limit 1;
>> Hope that helps,
>> Regina
>> http://postgis.us
>> http://postgis.net
>> -----Original Message-----
>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>> Behalf Of Jorge Gustavo Rocha
>> Sent: Monday, April 10, 2017 2:14 PM
>> To: postgis-users at lists.osgeo.org
>> Subject: Re: [postgis-users] PostGIS Out-DB Raster Not Behaving As
>> Expected
>> Hi,
>> According to the documentation [1], if you add the option -l (like -l
>> 2,4,8,16 ), the overviews are created in the database, even if you use
>> the -R option.
>> But since you did not use the -l option, I don't know how you can see the
>> images.
>> Can you check the layer properties in QGIS? Are any pyramids available or
>> not?
>> Regards,
>> Jorge
>>  s 16:52 de 10-04-2017, Osahon Oduware escreveu:
>> > Hi All,
>> > I created an out-db raster using the following syntax:
>> > raster2pgsql -s {srid} -c -R -I -C -F -t auto {absolute_file_path}
>> > public.{table} | psql -h {host} -p {port} -d {database} -U {user}
>> > The table was created successfully. I wanted to confirm that the
>> > actual file is being read from the location in the filesystem by
>> > performing the following steps:
>> > 1) I moved the raster file to a different location.
>> > 2) I opened QGIS and attempted to load the raster from PostGIS table.
>> > I was surprised that QGIS could load the file. *How is this possible
>> > when the actual raster data is not stored in the database table?*
>> > _______________________________________________
>> > postgis-users mailing list
>> > https://lists.osgeo.org/mailman/listinfo/postgis-users
>> J. Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Inform tica
>> Universidade do Minho
>> 4710-057 Braga
>> Tel: +351 253604480 <+351%20253%20604%20480>
>> Fax: +351 253604471 <+351%20253%20604%20471>
>> M vel: +351 910333888 <+351%20910%20333%20888>
>> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170411/8dfa55d2/attachment.html>
