[postgis-users] st_distance meter/degree
Olivier Leprêtre
o.lepretre at gmail.com
Thu Apr 13 03:56:36 PDT 2017
I don't understand why you see different units
First one does not return 1.33 but 1.33 10-5 so that is 0.0000133, the other is 0.0036239...
Olivier
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de franco base
Envoyé : jeudi 13 avril 2017 12:54
À : PostGIS Users Discussion
Objet : Re: [postgis-users] st_distance meter/degree
Thanks Jorge but it isn't the matter.
I'd know why postgis have a different way to calculate the distance
with the same sql query.
2017-04-13 12:37 GMT+02:00 Jorge Gustavo Rocha <jgr at di.uminho.pt>:
Hi Franco,
You can use the usual control statements IF THEN ELSE [1] to make it
exactly like you want.
[1]
https://www.postgresql.org/docs/current/static/plpgsql-control-structures.html
Regards,
Jorge
Às 10:57 de 13-04-2017, franco base escreveu:
> Hi all.
> Is it possible that st_distance between point return meter distance if
> point are very close and degrees otherwise?
> SELECT ST_distance ( ST_SetSRID
> (ST_MakePoint(45.4553804010375,9.11292550791171) ,4326), ST_SetSRID
> (ST_MakePoint(45.4553855607023,9.11291318106981) ,4326))
> return 1.3 ( meter distance)
> (ST_MakePoint(45.4560699405679,9.1164832309759) ,4326))
> return 0.003 (degrees distance)
> Thanks
> fb
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480 <tel:%2B351%20253604480>
Fax: +351 253604471 <tel:%2B351%20253604471>
Móvel: +351 910333888 <tel:%2B351%20910333888>
skype: nabocudnosor
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170413/46440063/attachment.html>
