[postgis-users] st_distance meter/degree
Jorge Gustavo Rocha
jgr at di.uminho.pt
Thu Apr 13 04:05:36 PDT 2017
Hi Franco,
I did not understood your question.
Postgis calculates the distance/area according to the CRS unit. It the
CRS unit is degrees, the results is in degrees. If the CRS unit is
meter, the result is in meter.
For example, if you transform the geometry, like:
SELECT ST_Distance(ST_Transform(geometry, 25829)) ...
the result will be in meter.
Regards,
Jorge
Às 11:54 de 13-04-2017, franco base escreveu:
> Thanks Jorge but it isn't the matter.
> I'd know why postgis have a different way to calculate the distance
> with the same sql query.
> 2017-04-13 12:37 GMT+02:00 Jorge Gustavo Rocha <jgr at di.uminho.pt
> <mailto:jgr at di.uminho.pt>>:
> Hi Franco,
> You can use the usual control statements IF THEN ELSE [1] to make it
> exactly like you want.
> [1]
> https://www.postgresql.org/docs/current/static/plpgsql-control-structures.html
> <https://www.postgresql.org/docs/current/static/plpgsql-control-structures.html>
> Regards,
> Jorge
> Às 10:57 de 13-04-2017, franco base escreveu:
> > Hi all.
> > Is it possible that st_distance between point return meter distance if
> > point are very close and degrees otherwise?
> > SELECT ST_distance ( ST_SetSRID
> > (ST_MakePoint(45.4553804010375,9.11292550791171) ,4326), ST_SetSRID
> > (ST_MakePoint(45.4553855607023,9.11291318106981) ,4326))
> > return 1.3 ( meter distance)
> > (ST_MakePoint(45.4560699405679,9.1164832309759) ,4326))
> > return 0.003 (degrees distance)
> > Thanks
> > fb
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> <https://lists.osgeo.org/mailman/listinfo/postgis-users>
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480 <tel:%2B351%20253604480>
> Fax: +351 253604471 <tel:%2B351%20253604471>
> Móvel: +351 910333888 <tel:%2B351%20910333888>
> skype: nabocudnosor
J. Gustavo
Jorge Gustavo Rocha
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
skype: nabocudnosor
