[postgis-users] st_distance meter/degree
franco base
frenk.calza at gmail.com
Thu Apr 13 04:07:41 PDT 2017
Sorry.
I don't see the 10-5at the end
very sorry
2017-04-13 13:05 GMT+02:00 Jorge Gustavo Rocha <jgr at di.uminho.pt>:
> Hi Franco,
> I did not understood your question.
> Postgis calculates the distance/area according to the CRS unit. It the
> CRS unit is degrees, the results is in degrees. If the CRS unit is
> meter, the result is in meter.
> For example, if you transform the geometry, like:
> SELECT ST_Distance(ST_Transform(geometry, 25829)) ...
> the result will be in meter.
> Regards,
> Jorge
> Às 11:54 de 13-04-2017, franco base escreveu:
> > Thanks Jorge but it isn't the matter.
> > I'd know why postgis have a different way to calculate the distance
> > with the same sql query.
> > 2017-04-13 12:37 GMT+02:00 Jorge Gustavo Rocha <jgr at di.uminho.pt
> > <mailto:jgr at di.uminho.pt>>:
> > Hi Franco,
> > You can use the usual control statements IF THEN ELSE [1] to make it
> > exactly like you want.
> > [1]
> > https://www.postgresql.org/docs/current/static/plpgsql-
> control-structures.html
> > <https://www.postgresql.org/docs/current/static/plpgsql-
> control-structures.html>
> > Regards,
> > Jorge
> > Às 10:57 de 13-04-2017, franco base escreveu:
> > > Hi all.
> > > Is it possible that st_distance between point return meter
> distance if
> > > point are very close and degrees otherwise?
> > > SELECT ST_distance ( ST_SetSRID
> > > (ST_MakePoint(45.4553804010375,9.11292550791171) ,4326),
> ST_SetSRID
> > > (ST_MakePoint(45.4553855607023,9.11291318106981) ,4326))
> > > return 1.3 ( meter distance)
> ST_SetSRID
> > > (ST_MakePoint(45.4560699405679,9.1164832309759) ,4326))
> > > return 0.003 (degrees distance)
> > > Thanks
> > > fb
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.
> osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/postgis-users
> > <https://lists.osgeo.org/mailman/listinfo/postgis-users>
> > J. Gustavo
> > Jorge Gustavo Rocha
> > Departamento de Informática
> > Universidade do Minho
> > 4710-057 Braga
> > Tel: +351 253604480 <tel:%2B351%20253604480>
> > Fax: +351 253604471 <tel:%2B351%20253604471>
> > Móvel: +351 910333888 <tel:%2B351%20910333888>
> > skype: nabocudnosor
> > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> J. Gustavo
> Jorge Gustavo Rocha
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170413/7ceb87f8/attachment.html>
