[postgis-users] Parallel linestring
Peter Devoy peter at 3xe.co.uk
Sat Apr 15 13:05:25 PDT 2017
It is difficult to visualise the problem but perhaps some combination
of ST_Difference and ST_Union could help you?
If the lines do not exactly overlap you could perhaps first grow all
geometries using ST_Buffer, then use ST_Union on the result, then
maybe use ST_ApproximateMedialAxis to get a line?
Good luck
Peter
