[postgis-users] Parallel linestring
Olivier Leprêtre o.lepretre at gmail.com
Mon Apr 17 05:02:08 PDT 2017
Thanks Peter,
I managed to reach my goal using ST_LineInterpolatePoint. Starting from Start/End points, I add a new point along each linestring couple every meter until I get a significant offset (let's say 50 cm). Storing the resulting point allows to build lines from start to this new point for vizualization purposes. It's also necessary to consider that start/ending point come from digitization, which returns lines in a random way, important to adjust when using ST_LineInterpolatePoint.
Olivier
-----Message d'origine-----
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Peter Devoy
Envoyé : samedi 15 avril 2017 22:05
À : PostGIS Users Discussion
Objet : Re: [postgis-users] Parallel linestring
It is difficult to visualise the problem but perhaps some combination of ST_Difference and ST_Union could help you?
If the lines do not exactly overlap you could perhaps first grow all geometries using ST_Buffer, then use ST_Union on the result, then maybe use ST_ApproximateMedialAxis to get a line?
Good luck
Peter
postgis-users mailing list
postgis-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/postgis-users
Hi
I would appreciate to get some suggestions to detect and convert semi-parallel linestring. I have Y shaped linestrings composed of two linestrings with a common part. My goal is to detect that there are two lines composing the Y trunk, merging them into a new one (or keeping only one of them) and placing a new node at the Y center, to get a result composed of three linestrings, one trunk and two branches. Lines have the same starting point at the bottom of the Y.
I tried to use toTopogeom but this does not help so far as it does not create a topopology when lines are parallels and close (0,03 meters as an example).
Any idea to detect the parallel part would be appreciated.
Thanks !
Olivier
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
