[postgis-users] [GENERAL] Error During PostGIS Build From Source on Linux
Osahon Oduware
osahon.gis at gmail.com
Tue Apr 18 06:38:42 PDT 2017
Hi Regina,
This suggestion helped to resolve the problem. Thanks a lot for your help.
On Mon, Apr 17, 2017 at 11:13 AM, Osahon Oduware <osahon.gis at gmail.com>
wrote:
> Hi Regina,
> Thanks a lot for your help. I believe this is where the solution lies. I
> would give it another try tomorrow when I resume work from the Easter break.
> I will update you with my findings.
> On Apr 16, 2017 4:52 AM, "Regina Obe" <lr at pcorp.us> wrote:
>> Osahon,
>> That error means you have installed an older version of GEOS in your
>> system and it's picking up the old one instead of the one in your
>> /home/nagispg/local/geos361/bin/geos-config
>> I suspect that's the same issue with your proj too.
>> I think doing an ldconfig after install of GEOS and proj might fix the
>> issue, but I forget.
>> It's been a while since I've had to compile the extra dependencies even
>> if building PostGIS on Linux.
>> Regarding the whole GDAL thing on windows.
>> I'm the builder of the Windows application Stackbuilder PostGIS bundle
>> and also manage the Windows PostGIS buildbot.
>> As I think someone mentioned, as a policy we don't compile any
>> proprietary extensions into the distributed windows PostGIS bundle.
>> So that's one reason why Mr. SID is not included and will probably never
>> be included.
>> However, you could convert Mr. SID format to something like OpenJpeg or
>> TIFF using GISInternals GDAL binaries for windows:
>> http://www.gisinternals.com/release.php
>> Last I tried, that one does have Mr. SID support. Unfortunately you
>> can't swap out his GDAL for the ones we package.
>> I was hoping I could make that possible at some point, but no free time
>> or enough funding interest to investigate.
>> Thanks,
>> Regina Obe
>> PostGIS PSC member
>> http://postgis.us
>> http://postgis.net
>> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
>> Behalf Of *Osahon Oduware
>> *Sent:* Friday, April 14, 2017 3:21 PM
>> *To:* Adrian Klaver <adrian.klaver at aklaver.com>
>> *Cc:* pgsql-general at postgresql.org; PostGIS Users Discussion <
>> postgis-users at lists.osgeo.org>
>> *Subject:* Re: [postgis-users] [GENERAL] Error During PostGIS Build From
>> Source on Linux
>> Hi Adrian,
>> I installed Proj from source and I can confirm that the file libproj.so.12
>> is in its lib folder.
>> I have not been able to confirm if it is linked to postgis-2.3.so as I
>> am away for Easter holiday.
>> Just in case, how do I do the linking of libproj.so.12 to postgis-2.3.so as
>> I believe this could be the cause of the error. Also, I tried earlier to
>> copy the file to the PostgreSQL lib folder and this time when I try to run
>> "CREATE EXTENSION postgis;" I get the initial error:
>> ERROR: could not load library "/path/to/postgresql/lib/postgis-2.3.so":
>> /path/to/postgresql/lib/postgis-2.3.so: undefined symbol: GEOSClipByRect
>> I will be glad if anyone could help with this.
>> On Apr 13, 2017 18:27, "Adrian Klaver" <adrian.klaver at aklaver.com> wrote:
>> On 04/13/2017 07:54 AM, Osahon Oduware wrote:
>> Hi Adrian,
>> Thanks for your help so far. This is the output of the PostGIS
>> configuration:
>> -------------- Compiler Info -------------
>> C compiler: gcc -g -O2
>> SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
>> -------------- Dependencies --------------
>> GEOS config: /home/nagispg/local/geos361/bin/geos-config
>> GEOS version: 3.6.1
>> GDAL config: /home/nagispg/local/gdal213/bin/gdal-config
>> GDAL version: 2.1.3
>> PostgreSQL config: /home/nagispg/local/pgsql/bin/pg_config
>> PostgreSQL version: PostgreSQL 9.6.2
>> PROJ4 version: 49
>> Libxml2 config: /usr/bin/xml2-config
>> Libxml2 version: 2.7.6
>> JSON-C support: no
>> PCRE support: no
>> PostGIS debug level: 0
>> Perl: /usr/bin/perl
>> --------------- Extensions ---------------
>> PostGIS Raster: enabled
>> PostGIS Topology: enabled
>> SFCGAL support: disabled
>> Address Standardizer support: disabled
>> -------- Documentation Generation --------
>> xsltproc: /usr/bin/xsltproc
>> xsl style sheets:
>> dblatex:
>> convert: /usr/bin/convert
>> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>> <http://www.w3.org/Math/DTD/mathml2/mathml2.dtd>
>> I had to install a *higher version of Proj (4.9.3)* that was used to
>> configure PostGIS (I think I read somewhere in the documentation that
>> the version of Proj should be >= 4.6.0). *Now, I get the following error
>> when I run CREATE EXTENSION postgis:*
>> How did you install Proj, from a package or source?
>> *ERROR: could not load library postgis-2.3.so <http://postgis-2.3.so>:
>> libproj.so.12: cannot open shared object file: No such file or directory*
>> First find postgis-2.3.so and do:
>> ldd postgis-2.3.so
>> It should show something like:
>> linux-vdso.so.1 (0x00007ffe3ed8a000)
>> libgeos_c.so.1 => /usr/lib64/libgeos_c.so.1 (0x00007f975bd09000)
>> ==> libproj.so.9 => /usr/lib64/libproj.so.9 (0x00007f975baaa000)
>> libxml2.so.2 => /usr/lib64/libxml2.so.2 (0x00007f975b73f000)
>> libm.so.6 => /lib64/libm.so.6 (0x00007f975b442000)
>> libc.so.6 => /lib64/libc.so.6 (0x00007f975b09e000)
>> libgeos-3.5.1.so => /usr/lib64/libgeos-3.5.1.so
>> (0x00007f975acef000)
>> libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007f975a966000)
>> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f975a74e000)
>> libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f975a531000)
>> libdl.so.2 => /lib64/libdl.so.2 (0x00007f975a32d000)
>> libz.so.1 => /lib64/libz.so.1 (0x00007f975a116000)
>> liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007f9759eed000)
>> /lib64/ld-linux-x86-64.so.2 (0x000055ebafa02000)
>> That will verify if postgis-2.3.so is linked to libproj.
>> I would be glad if someone could point me to what I am doing wrong and
>> possible solution.
>> Adrian Klaver
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170418/c3feaa16/attachment.html>
