[postgis-users] [GENERAL] Error During PostGIS Build From Source on Linux
Osahon Oduware
osahon.gis at gmail.com
Mon Apr 17 03:13:33 PDT 2017
Hi Regina,
Thanks a lot for your help. I believe this is where the solution lies. I
would give it another try tomorrow when I resume work from the Easter break.
I will update you with my findings.
On Apr 16, 2017 4:52 AM, "Regina Obe" <lr at pcorp.us> wrote:
> Osahon,
> That error means you have installed an older version of GEOS in your
> system and it's picking up the old one instead of the one in your
> /home/nagispg/local/geos361/bin/geos-config
> I suspect that's the same issue with your proj too.
> I think doing an ldconfig after install of GEOS and proj might fix the
> issue, but I forget.
> It's been a while since I've had to compile the extra dependencies even if
> building PostGIS on Linux.
> Regarding the whole GDAL thing on windows.
> I'm the builder of the Windows application Stackbuilder PostGIS bundle and
> also manage the Windows PostGIS buildbot.
> As I think someone mentioned, as a policy we don't compile any proprietary
> extensions into the distributed windows PostGIS bundle.
> So that's one reason why Mr. SID is not included and will probably never
> be included.
> However, you could convert Mr. SID format to something like OpenJpeg or
> TIFF using GISInternals GDAL binaries for windows:
> http://www.gisinternals.com/release.php
> Last I tried, that one does have Mr. SID support. Unfortunately you can't
> swap out his GDAL for the ones we package.
> I was hoping I could make that possible at some point, but no free time or
> enough funding interest to investigate.
> Thanks,
> Regina Obe
> PostGIS PSC member
> http://postgis.us
> http://postgis.net
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Osahon Oduware
> *Sent:* Friday, April 14, 2017 3:21 PM
> *To:* Adrian Klaver <adrian.klaver at aklaver.com>
> *Cc:* pgsql-general at postgresql.org; PostGIS Users Discussion <
> postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] [GENERAL] Error During PostGIS Build From
> Source on Linux
> Hi Adrian,
> I installed Proj from source and I can confirm that the file libproj.so.12
> is in its lib folder.
> I have not been able to confirm if it is linked to postgis-2.3.so as I am
> away for Easter holiday.
> Just in case, how do I do the linking of libproj.so.12 to postgis-2.3.so as
> I believe this could be the cause of the error. Also, I tried earlier to
> copy the file to the PostgreSQL lib folder and this time when I try to run
> "CREATE EXTENSION postgis;" I get the initial error:
> ERROR: could not load library "/path/to/postgresql/lib/postgis-2.3.so":
> /path/to/postgresql/lib/postgis-2.3.so: undefined symbol: GEOSClipByRect
> I will be glad if anyone could help with this.
> On Apr 13, 2017 18:27, "Adrian Klaver" <adrian.klaver at aklaver.com> wrote:
> On 04/13/2017 07:54 AM, Osahon Oduware wrote:
> Hi Adrian,
> Thanks for your help so far. This is the output of the PostGIS
> configuration:
> -------------- Compiler Info -------------
> C compiler: gcc -g -O2
> SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
> -------------- Dependencies --------------
> GEOS config: /home/nagispg/local/geos361/bin/geos-config
> GEOS version: 3.6.1
> GDAL config: /home/nagispg/local/gdal213/bin/gdal-config
> GDAL version: 2.1.3
> PostgreSQL config: /home/nagispg/local/pgsql/bin/pg_config
> PostgreSQL version: PostgreSQL 9.6.2
> PROJ4 version: 49
> Libxml2 config: /usr/bin/xml2-config
> Libxml2 version: 2.7.6
> JSON-C support: no
> PCRE support: no
> PostGIS debug level: 0
> Perl: /usr/bin/perl
> --------------- Extensions ---------------
> PostGIS Raster: enabled
> PostGIS Topology: enabled
> SFCGAL support: disabled
> Address Standardizer support: disabled
> -------- Documentation Generation --------
> xsltproc: /usr/bin/xsltproc
> xsl style sheets:
> dblatex:
> convert: /usr/bin/convert
> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> <http://www.w3.org/Math/DTD/mathml2/mathml2.dtd>
> I had to install a *higher version of Proj (4.9.3)* that was used to
> configure PostGIS (I think I read somewhere in the documentation that
> the version of Proj should be >= 4.6.0). *Now, I get the following error
> when I run CREATE EXTENSION postgis:*
> How did you install Proj, from a package or source?
> *ERROR: could not load library postgis-2.3.so <http://postgis-2.3.so>:
> libproj.so.12: cannot open shared object file: No such file or directory*
> First find postgis-2.3.so and do:
> ldd postgis-2.3.so
> It should show something like:
> linux-vdso.so.1 (0x00007ffe3ed8a000)
> libgeos_c.so.1 => /usr/lib64/libgeos_c.so.1 (0x00007f975bd09000)
> ==> libproj.so.9 => /usr/lib64/libproj.so.9 (0x00007f975baaa000)
> libxml2.so.2 => /usr/lib64/libxml2.so.2 (0x00007f975b73f000)
> libm.so.6 => /lib64/libm.so.6 (0x00007f975b442000)
> libc.so.6 => /lib64/libc.so.6 (0x00007f975b09e000)
> libgeos-3.5.1.so => /usr/lib64/libgeos-3.5.1.so
> (0x00007f975acef000)
> libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007f975a966000)
> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f975a74e000)
> libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f975a531000)
> libdl.so.2 => /lib64/libdl.so.2 (0x00007f975a32d000)
> libz.so.1 => /lib64/libz.so.1 (0x00007f975a116000)
> liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007f9759eed000)
> /lib64/ld-linux-x86-64.so.2 (0x000055ebafa02000)
> That will verify if postgis-2.3.so is linked to libproj.
> I would be glad if someone could point me to what I am doing wrong and
> possible solution.
> Adrian Klaver
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170417/4f1a8e20/attachment.html>
