[postgis-users] ST_Area(geog): ptarray_area_spheroid: cannot handle ptarray that crosses equator
Peter Schmitt
pschmitt at gmail.com
Mon Aug 21 14:33:58 PDT 2017
Thanks Regina! Yes, it must be something with the version of GEOS, PROJ or
GDAL. The query works fine on a AWS RDS instance with
POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.2, 08
September 2015" GDAL="GDAL 2.0.3, released 2016/07/01" LIBXML="2.9.1"
LIBJSON="0.12" RASTER
but failed with this Docker image: https://hub.docker.com/r/mdillon/postgis/
POSTGIS="2.3.2 r15302" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.9.1"
LIBJSON="0.11.99" RASTER
Thanks again!
Pete
On Mon, Aug 21, 2017 at 3:05 PM, Regina Obe <lr at pcorp.us> wrote:
> Hmm something seems a little fishy with this. I'm running 2.3.3 so I
> guess it's possible it's something we fixed in PostGIS 2.3.3.
> When I run:
> SELECT ST_Area(ST_GeographyFromText('POLYGON((40 0.009,40.1 0.009,40.1
> 0,40 0,40 0.009))'));
> I get:
> 11078167.65815
> I think since version 2.2.0 or 2.3, I forget which, the geographicLab
> library (which requires Proj 4.9+) kicks in so it's possible I'm not having
> the same issue because I'm using a newer Proj version so I'm using the
> improved calc stuff.
> This is the version I'm using.
> POSTGIS="2.3.3 r15473" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1, 04
> March 2015" GDAL="GDAL 2.2.1, released 2017/06/23" LIBXML="2.7.8"
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Peter Schmitt
> *Sent:* Monday, August 21, 2017 4:31 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] ST_Area(geog): ptarray_area_spheroid: cannot
> Hi,
> The following query:
> returns the error:
> I am using Postgis-2.3 provided by https://hub.docker.com/r/
> mdillon/postgis/
> postgis_full_version = POSTGIS="2.3.2 r15302" GEOS="3.4.2-CAPI-1.8.2
> r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1, released
> 2013/08/26" LIBXML="2.9.1" LIBJSON="0.11.99" RASTER
> I believe the geometry is valid. I can pass the error by
> setting use_spheroid=false, like so:
> 0,40 0,40 0.009))'), false);
> However, I would like to use the sphere everywhere else in my
> application. Can anyone provide some insight? I found something reporting
> this should not hapen on Postgis >= 2.2: https://gis.
> stackexchange.com/questions/169436/postgis-polygons-lying-
> on-the-equator/169482#169482
> Thanks!
> Pete
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Pete
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170821/6f35cc2f/attachment.html>
