[postgis-users] ST_Area(geog): ptarray_area_spheroid: cannot handle ptarray that crosses equator
Paul Ramsey pramsey at cleverelephant.ca
Fri Aug 25 10:24:14 PDT 2017
I think at proj 4.9 we flip over to using the geodetic functions in proj,
which are more robust and have fewer failure modes.
P
On Mon, Aug 21, 2017 at 2:33 PM, Peter Schmitt <pschmitt at gmail.com> wrote:
> Thanks Regina!  Yes, it must be something with the version of GEOS, PROJ
> or GDAL.  The query works fine on a AWS RDS instance with
> POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.2, 08
> September 2015" GDAL="GDAL 2.0.3, released 2016/07/01" LIBXML="2.9.1"
> LIBJSON="0.12" RASTER
> but failed with this Docker image: https://hub.docker.com/
> r/mdillon/postgis/
> POSTGIS="2.3.2 r15302" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
> March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.9.1"
> LIBJSON="0.11.99" RASTER
> Thanks again!
> Pete
> On Mon, Aug 21, 2017 at 3:05 PM, Regina Obe <lr at pcorp.us> wrote:
>> Hmm something seems a little fishy with this.  I'm running 2.3.3 so I
>> guess it's possible it's something we fixed in PostGIS 2.3.3.
>> When I run:
>> SELECT ST_Area(ST_GeographyFromText('POLYGON((40 0.009,40.1 0.009,40.1
>> 0,40 0,40 0.009))'));
>> I get:
>> 11078167.65815
>> I think since version 2.2.0 or 2.3, I forget which, the geographicLab
>> library (which requires Proj 4.9+) kicks in so it's possible I'm not having
>> the same issue because I'm using a newer Proj version so I'm using the
>> improved calc stuff.
>> This is the version I'm using.
>> POSTGIS="2.3.3 r15473" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1,
>> 04 March 2015" GDAL="GDAL 2.2.1, released 2017/06/23" LIBXML="2.7.8"
>> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
>> Behalf Of *Peter Schmitt
>> *Sent:* Monday, August 21, 2017 4:31 PM
>> *To:* postgis-users at lists.osgeo.org
>> *Subject:* [postgis-users] ST_Area(geog): ptarray_area_spheroid: cannot
>> Hi,
>> The following query:
>> 0.009,40.1 0,40 0,40 0.009))'));
>> returns the error:
>> I am using Postgis-2.3 provided by https://hub.docker.com/r/md
>> illon/postgis/
>> postgis_full_version =  POSTGIS="2.3.2 r15302" GEOS="3.4.2-CAPI-1.8.2
>> r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1, released
>> 2013/08/26" LIBXML="2.9.1" LIBJSON="0.11.99" RASTER
>> I believe the geometry is valid.  I can pass the error by
>> setting use_spheroid=false, like so:
>> 0,40 0,40 0.009))'), false);
>> However, I would like to use the sphere everywhere else in my
>> application.  Can anyone provide some insight?  I found something reporting
>> this should not hapen on Postgis >= 2.2: https://gis.stackexchange
>> .com/questions/169436/postgis-polygons-lying-on-the-equator/169482#169482
>> Thanks!
>> Pete
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Pete
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170825/f98780a1/attachment.html>
