[postgis-users] Given up
Darrel Maddy
darrel.maddy at newcastle.ac.uk
Mon Dec 11 05:40:23 PST 2017
Dear Regina,
Yes I think this was a mess of my own making! As usual I was trying to do this in a rush - I had installed Qgis and geoserver for a project I am starting and then realised I had not installed postgresql/postgis and that is where my problems started. One thing I should have learned over the years is to prepare properly and not try to do these things on the fly.
Everything is now installed and things appear to be 'working'. Whether this combination will work in harmony is another matter - we will see.
Apologies once more for venting my frustration at my own incompetence.
Best wishes
Darrel
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Regina Obe
Sent: 11 December 2017 13:23
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Given up
Darrel,
There was an issue with when PostgreSQL 10 came out that the stack builder did not show the PostGIS spatial extension I had uploaded.
This was fixed in PostgreSQL 10.1 so perhaps you went to it pre-10.1.
Regarding not creating spatial db, that is odd. There is a checkbox to create one, but I do have it unchecked by default, cause it's better for people to just use CREATE EXTENSION on whatever database they want. I keep that feature there just so I can test when I deploy to make sure all extensions can be created.
As noted by Bo below, BigSQL packages PostGIS too and that one IS NOT VIA STACKBUILDER. STACKBUILDER is for EDB installs.
Use pgc commandline or pgDevOps for BigSQL.
However, the EDB windows and BigSQL Windows binaries are compatible (both compiled with mingw64), so if you ever need anything you can't find in BigSQL (pgRouting and SFCGAL come to mind)
You can use the zip binaries on this page -
https://postgis.net/windows_downloads/
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Bo Victor Thomsen
Sent: Monday, December 11, 2017 4:14 AM
To: postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
Hi Darrel -
As you already have found an alternative installation, this mail is just a heads-up for future users of the BigSQL installation of PostgreSQL:
* The BigSQL administrative interface is based on some kind of local http-server software, which serves a JavaScript based program for installing/upgrading PostgreSQL and extensions (localhost:8051 IIRC)
* This works very nicely (some times). But depending on your choice of antivirus - it can be a *royal* pain, because *your* antivirus software a lot of the time will stop *you* from using the interface.
* However, BigSQL has an alternative installation method: the pgc command line interface.
* You can do the following:
o Start a DOS box with administrative rights (Right-click the dox-box icon, choose "Run as Administrator")
o In the dos box, navigate to the installation directory of BigSQL, usually c:\PostgreSQL or c:\BigSQL
o type "pgc" . This will give you a list of supported command for pgc.
o Example - Install the PostGIS 2.4 extension for PostgreSQL: type "pgc install postgis24-pg10"
o Give it a minute to download and install and then: Voila! you have the PostGIS extension for PostgreSQL installed and ready for use.
Regards
Bo Victor Thomsen
LIFA A/S, Denmark
Den 10-12-2017 kl. 20:29 skrev Darrel Maddy:
Dear all,
This is probably not the best time for me to be writing this but I think it is sometimes useful to report negative outcomes.
I have a new laptop running windows 10. I have not installed postgresql or postgis for some time so I decided to use the binaries. Using the BIGSQL download proved to be a nightmare. Postgresql 10 installs without issue but with no stackbuilder option (it does not appear anywhere in the menus nor in the directories) I attempted to try and install the postgis binaries. Needless to say that failed with repeated errors for files it could not find. I have spent a few hours trying to convince this that the files are there but now I have given up. To add insult to injury the postgis uninstall did not work and the postgresql uninstall failed to remove most of its components. God knows what mess it has made of any registry entries (assuming it does that). I tried 9.6 but stackbuilder did not appear there either so I have lost whatever patience I may have started out with. I realise the install instructions do not refer to the latest versions but I reluctantly admit failure. May be I just cannot follow instructions?
Perhaps as I get older I forget previous experience but I do not remember it being such a mess previously. Maybe I will try again in a month or two - is the situation likely to improve?
Sorry but I needed to get this off my chest and the criticism is NOT aimed at anyone in particular.
Darrel
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171211/a446e226/attachment.html>
