[postgis-users] st_geojson like st_mvt function
Rémi Desgrange
rdesgrange at gmail.com
Tue Dec 12 12:56:11 PST 2017
this is my first mail on this list, I didn't know if I should have posted
on dev list or this one. Don't hesitate to correct.
With postgis 2.4 we now have the possibility to generate mvt format
directly in SQL, what I really like is the ability to construct a mvt
response with geometrie + data. The sql result is directly well formated
and ready to use. When I need to use geojson in my app I need something
like that :
{ "type": "Feature",
"geometry":
"type": "Point",
"coordinates": [125.6, 10.1]
"properties": { "name": "Dinagat Islands" }
In order to do that I do :
SELECT name, st_geojson(geom) as geom FROM mytable
And then I my code I manipulate "name" to put it in the json under
"properties" there hack around to directly return geojson, but they're hack
not actual solutions.
What I imagine is something like that :
SELECT st_geojson(x) FROM (SELECT name, geom FROM mytable) x
the signature would be :
text St_AsGeoJSON(anyelement set row)
I do not know if this question has already been asked, I found nothing when
I googled. Do you think that this is a legitimate feature request ?
Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171212/70ecb1b2/attachment.html>
