[postgis-users] Given up
Tijan49
tijan49 at yahoo.fr
Mon Dec 11 11:51:26 PST 2017
Some time ago I installed PostgreSQL with the DBEntreprise installer,
but it was coming with the PgAdmin 4,witch I really didn't appreciate
(mostly because it runs really slowly in comparison with PgAdmin3 on my
machine ...).
For that reason I came back to PostgreSQL 9.6.
Do you know If it's now possible to have PostgreSQL 10 installed with
PgAdmin 3 (or if PgAdmin 4 has dealt with his problems of slowness, wich
many people have noticed) ?
Thanks,
Jean
Le 11/12/2017 à 20:24, Anthony DeBarros a écrit :
> Thanks, Regina,
> Nope, Postgres.app doesn’t include it. Haven’t successfully found an
> alternative.
> Anthony
> On December 11, 2017 at 1:17:19 PM, Regina Obe (lr at pcorp.us
> <mailto:lr at pcorp.us>) wrote:
>> Anthony,
>> Sorry no clue about Mac. I thought perhaps Postgres.app might have it
>> http://postgresapp.com/documentation/gui-tools.html
>> but don't see it listed under their Gui Client apps. It's possible
>> they missed listing it and they have it.
>> I see the PostGIS commandline tools listed under CLI apps though
>> http://postgresapp.com/documentation/cli-tools.html
>> Thanks,
>> Regina
>> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
>> <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of
>> *Anthony DeBarros
>> *Sent:* Monday, December 11, 2017 8:41 AM
>> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org
>> <mailto:postgis-users at lists.osgeo.org>>
>> *Subject:* Re: [postgis-users] Given up
>> Regina (or anyone),
>> I had posted a couple weeks back about not being able to find a
>> version of the Shapefile Loader GUI that works under macOS High
>> Sierra. The one I recently downloaded from Boundless doesn’t work.
>> Any ideas on alternates?
>> Thanks,
>> Anthony
>> On December 11, 2017 at 8:23:31 AM, Regina Obe (lr at pcorp.us
>> Darrel,
>> There was an issue with when PostgreSQL 10 came out that the
>> stack builder did not show the PostGIS spatial extension I had
>> uploaded.
>> This was fixed in PostgreSQL 10.1 so perhaps you went to it pre-10.1.
>> Regarding not creating spatial db, that is odd. There is a
>> checkbox to create one, but I do have it unchecked by default,
>> cause it's better for people to just use CREATE EXTENSION on
>> whatever database they want. I keep that feature there just so I
>> can test when I deploy to make sure all extensions can be created.
>> As noted by Bo below, BigSQL packages PostGIS too and that one IS
>> NOT VIA STACKBUILDER. STACKBUILDER is for EDB installs.
>> Use pgc commandline or pgDevOps for BigSQL.
>> However, the EDB windows and BigSQL Windows binaries are
>> compatible (both compiled with mingw64), so if you ever need
>> anything you can't find in BigSQL (pgRouting and SFCGAL come to mind)
>> You can use the zip binaries on this page –
>> https://postgis.net/windows_downloads/
>> Thanks,
>> Regina
>> *From:* postgis-users
>> <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Bo
>> Victor Thomsen
>> *Sent:* Monday, December 11, 2017 4:14 AM
>> *To:* postgis-users at lists.osgeo.org
>> Hi Darrel -
>> As you already have found an alternative installation, this mail
>> is just a heads-up for future users of the BigSQL installation of
>> PostgreSQL:
>> ·The BigSQL administrative interface is based on some kind of
>> local http-server software, which serves a JavaScript based
>> program for installing/upgrading PostgreSQL and extensions
>> (localhost:8051 IIRC)
>> ·This works very nicely (some times). But depending on your
>> choice of antivirus - it can be a *royal* pain, because *your*
>> antivirus software a lot of the time will stop *you* from using
>> the interface.
>> ·However, BigSQL has an alternative installation method: the
>> *pgc* command line interface.
>> ·You can do the following:
>> oStart a DOS box with administrative rights (Right-click the
>> dox-box icon, choose "Run as Administrator")
>> oIn the dos box, navigate to the installation directory of
>> BigSQL, usually c:\PostgreSQL or c:\BigSQL
>> otype "pgc" . This will give you a list of supported command for pgc.
>> oExample - Install the PostGIS 2.4 extension for PostgreSQL: type
>> "*pgc install postgis24-pg10*"
>> oGive it a minute to download and install and then: Voila! you
>> have the PostGIS extension for PostgreSQL installed and ready for
>> use.
>> Regards
>> Bo Victor Thomsen
>> LIFA A/S, Denmark
>> Den 10-12-2017 kl. 20:29 skrev Darrel Maddy:
>> Dear all,
>> This is probably not the best time for me to be writing this
>> but I think it is sometimes useful to report negative outcomes.
>> I have a new laptop running windows 10. I have not installed
>> postgresql or postgis for some time so I decided to use the
>> binaries. Using the BIGSQL download proved to be a nightmare.
>> Postgresql 10 installs without issue but with no stackbuilder
>> option (it does not appear anywhere in the menus nor in the
>> directories) I attempted to try and install the postgis
>> binaries. Needless to say that failed with repeated errors
>> for files it could not find. I have spent a few hours trying
>> to convince this that the files are there but now I have
>> given up. To add insult to injury the postgis uninstall did
>> not work and the postgresql uninstall failed to remove most
>> of its components. God knows what mess it has made of any
>> registry entries (assuming it does that). I tried 9.6 but
>> stackbuilder did not appear there either so I have lost
>> whatever patience I may have started out with. I realise the
>> install instructions do not refer to the latest versions but
>> I reluctantly admit failure. May be I just cannot follow
>> instructions?
>> Perhaps as I get older I forget previous experience but I do
>> not remember it being such a mess previously. Maybe I will
>> try again in a month or two – is the situation likely to
>> improve?
>> Sorry but I needed to get this off my chest and the criticism
>> is NOT aimed at anyone in particular.
>> Darrel
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171211/9d9317c1/attachment.html>
