[postgis-users] HELP - Geometrycollection - CREATE VIEW - Empty Table
Tõnis Kärdi
Tonis.Kardi at kemit.ee
Thu Dec 14 05:11:14 PST 2017
Hi Oli,
Have you checked the distinct values you are getting for geometrytype? Something in the lines of
select distinct geometrytype(geom) from cp_parcel_postgis;
Is 'GEOMETRYCOLLECTION(POLYGON)' listed there?
I think the geometrytype of a geometrycollection is simply 'GEOMETRYCOLLECTION'. So most probably the filter you are using filters everything out.
All the best,
Tõnis
________________________________________
Saatja: postgis-users <postgis-users-bounces at lists.osgeo.org> ofoerster at posteo.de <ofoerster at posteo.de> nimel
Saadetud: 14. detsember 2017 14:30
Adressaat: postgis-users at lists.osgeo.org
Teema: [postgis-users] HELP - Geometrycollection - CREATE VIEW - Empty Table
Hello PostGIS Community,
I have a Problem. I have a table with a geometry collection (polygon and
point).
QGIS can not read the geometry collection, so I want to create a view
for the polygon type and the point type. My SQL function for the polygon
type looks like this:
CREATE VIEW parcel_polygons AS (
SELECT
row_number() OVER(ORDER BY inspire_local DESC) AS OID
, inspire_local
, inspire_namespace
, label
, nationalcadref
, areavalue
, validfrom
, beginlifespanversion
, zoning
, geom::geometry(Polygon, 25833)
FROM cp_parcel_postgis
WHERE GeometryType(geom) = 'GEOMETRYCOLLECTION(POLYGON)'
I do not get any errors and the view is created. Unfortunately, the view
is empty.
What am I doing wrong?
Thanks for any help,
Oli
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
