[postgis-users] error while loading dat for tiger geocoder
David M. Kaplan david.kaplan at ird.fr
Tue Dec 19 03:49:34 PST 2017
I am in the process of setting up the tiger geocoder for use with
addresses from the state of virginia. I am using PostgreSQL 9.3.20,
postgis 2.2.2 and postgis_tiger_geocoder 2.2.2.
The state loader script (for linux shell) generates an SQL error towards
the end of the script relating to the following line (line 210 in my
script):
${PSQL} -c "ALTER TABLE tiger_staging.VA_tabblock RENAME geoid10 TO
tabblock_id;"
The error it generates is:
ERROR:  relation "tiger_staging.va_tabblock" does not exist
I am under the impression that this error is harmless as at this stage
the tiger_staging schema is empty because the function
loader_load_staged_data() has already been run, but I want to make sure.
If this is indeed a harmless error, then why is this line in the script?
Thanks,
David
David M. Kaplan
Charge de Recherche 1
Institut de Recherche pour le Developpement (IRD)
UMR MARBEC (IRD/Ifremer/CNRS/UMII)
av. Jean Monnet
CS 30171
34203 Sete cedex
France
Phone: +33 (0)4 99 57 32 25
Fax: +33 (0)4 99 57 32 95
http://www.umr-marbec.fr/kaplan-david.html
