[postgis-users] screen copy with postgis
Olivier Leprêtre o.lepretre at gmail.com
Wed Feb 22 23:58:56 PST 2017
Thanks for this answer Thomas, you confirm what I guessed also. Before considering this way, I had a look about attributes and didn't find how I could create raster texts layer, to display gid or other information. So I wonder if I should better not carrying on with Postgis for that but try another way...
Olivier
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Tumasgiu Rossini
Envoyé : mercredi 22 février 2017 22:56
À : PostGIS Users Discussion
Objet : Re: [postgis-users] screen copy with postgis
I'm not sure there is a function that can burns geometries on an existing
raster.
So I guess you will need to create a raster for each "layer" you want to
draw (e.g. the polygons, the boundaries...) and merge them into a
final raster using st_mapalgebra.
2017-02-22 21:48 GMT+01:00 Olivier Leprêtre <o.lepretre at gmail.com>:
I'm trying to do a "screen copy" from a set of polygons. So I thought that I could use St_AsRaster and St_AsJpeg as follow, with the selection of two poly.
SELECT ST_AsJPEG(ST_AsRaster(st_collect((Select geom from poly where gid=605530),(Select geom from poly where gid=605533)),1000,1000, ARRAY['8BUI', '8BUI', '8BUI'], ARRAY[255,255,255], ARRAY[0,0,0],null,null,0,0,true))
I load the result in a C# app which is in charge to save it as a file. This "works" but I'm loosing the boundaries (tha't to say the red lines in the image below).
1)    Is there a way to keep those boundaries ?
2)    As I have other layers, like texts, will it be possible to make them appear also, like a screen copy ?
In other words, more simply, am I on the right way or should I think to a completely different solution ?
Thanks,
Olivier
cid:image001.jpg at 01D28DB2.F9256BC0
  _____
 <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> Avast logo
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
www.avast.com <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
postgis-users mailing list
 <mailto:postgis-users at lists.osgeo.org> postgis-users at lists.osgeo.org
 <https://lists.osgeo.org/mailman/listinfo/postgis-users> https://lists.osgeo.org/mailman/listinfo/postgis-users
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170223/c4e6f655/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170223/c4e6f655/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170223/c4e6f655/attachment.png>
