[postgis-users] screen copy with postgis
Tumasgiu Rossini rossini.t at gmail.com
Thu Feb 23 00:27:27 PST 2017
I don't think there is a function to transform text into polygon
in postgis, though it can be feasible.
Looks like you gonna need to code a little more.
If you decide to stick to C#, you could use things like
dotspatial or sharpmap.
You could also just use the Npgqsl ADO connector to avoid
too many depedencies and do the math yourself.
Npgsql has built-in types for handling postgis geometries.
2017-02-23 8:58 GMT+01:00 Olivier Leprêtre <o.lepretre at gmail.com>:
> Hi,
> Thanks for this answer Thomas, you confirm what I guessed also. Before
> considering this way, I had a look about attributes and didn't find how I
> could create raster texts layer, to display gid or other information. So I
> wonder if I should better not carrying on with Postgis for that but try
> another way...
> Olivier
> *De :* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *De
> la part de* Tumasgiu Rossini
> *Envoyé :* mercredi 22 février 2017 22:56
> *À :* PostGIS Users Discussion
> *Objet :* Re: [postgis-users] screen copy with postgis
> Hi,
> I'm not sure there is a function that can burns geometries on an existing
> raster.
> So I guess you will need to create a raster for each "layer" you want to
> draw (e.g. the polygons, the boundaries...) and merge them into a
> final raster using st_mapalgebra.
> 2017-02-22 21:48 GMT+01:00 Olivier Leprêtre <o.lepretre at gmail.com>:
> Hi,
> I'm trying to do a "screen copy" from a set of polygons. So I thought that
> I could use St_AsRaster and St_AsJpeg as follow, with the selection of two
> poly.
> SELECT ST_AsJPEG(ST_AsRaster(st_collect((Select geom from poly where
> gid=605530),(Select geom from poly where gid=605533)),1000,1000,
> ARRAY['8BUI', '8BUI', '8BUI'], ARRAY[255,255,255],
> ARRAY[0,0,0],null,null,0,0,true))
> I load the result in a C# app which is in charge to save it as a file.
> This "works" but I'm loosing the boundaries (tha't to say the red lines in
> the image below).
> 1)    Is there a way to keep those boundaries ?
> 2)    As I have other layers, like texts, will it be possible to make
> them appear also, like a screen copy ?
> In other words, more simply, am I on the right way or should I think to a
> completely different solution ?
> Thanks,
> Olivier
> [image: cid:image001.jpg at 01D28DB2.F9256BC0]
> [image: Avast logo]
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
> L'absence de virus dans ce courrier électronique a été vérifiée par le
> logiciel antivirus Avast.
> www.avast.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> [image: Avast logo]
> www.avast.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170223/4076aef3/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170223/4076aef3/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170223/4076aef3/attachment.png>
