[postgis-users] Understanding 3d bbox filtering support
Andrea Aime andrea.aime at geo-solutions.it
Wed Jan 18 05:47:41 PST 2017
I'm trying to perform a "simple" 3d bounding box filter against a dataset
with 3d coordinates
and I'm getting some funny/weird results. I am using postgis 2.2.
The table looks as follows:
                                        Table "public.3dfloor"
   Column   |             Type              |
 Modifiers
 gid        | integer                       | not null default
nextval('"3dfloor_gid_seq"'::regclass)
 newfeat_id | integer                       |
 geom       | geometry(MultiPolygonZ,7415) |
Indexes:
    "3dfloor_pkey" PRIMARY KEY, btree (gid)
    "3dfloor_geom_idx" gist (geom gist_geometry_ops_nd)
The index has been created with ND support. Now, the table contains 16 rows
with varying Z values,
sample summary here:
> select gid, ST_ZMin(geom), ST_ZMax(geom) from "3dfloor";
 gid | st_zmin | st_zmax
   1 |       0 |       0
   2 |       0 |       0
   3 |       3 |       3
   4 |       6 |       6
   5 |       9 |       9
   6 |      12 |      12
   7 |      15 |      15
   8 |      18 |      18
   9 |      21 |      21
  10 |      24 |      24
  11 |      27 |      27
  12 |      30 |      30
  13 |      33 |      33
  14 |      36 |      36
  15 |      39 |      39
  16 |      42 |      42
I'm trying to filter using a 3d bbox, but I'm getting back all rows while I
would expect to get only the first two, instead I'm getting
back all of them:
> select count(*) from "3dfloor" where geom &&&
ST_3DMakeBox(ST_makePoint(0,0,0), ST_MakePoint(1000000,1000000,1));
16
Anyone knows why it's happening? Hopefully I'm missing something obvious :-)
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170118/6e7600a5/attachment.html>
