[postgis-users] Understanding 3d bbox filtering support
Rémi Cura remi.cura at gmail.com
Wed Jan 18 08:13:49 PST 2017
Hey,
I can't test right now,
but :
 - you have the same srid for object and bbox right?
 - I remember Sandro discussing this case
Cheers,
Rémi-C
2017-01-18 14:47 GMT+01:00 Andrea Aime <andrea.aime at geo-solutions.it>:
> Hi,
> I'm trying to perform a "simple" 3d bounding box filter against a dataset
> with 3d coordinates
> and I'm getting some funny/weird results. I am using postgis 2.2.
> The table looks as follows:
>                                         Table "public.3dfloor"
>    Column   |             Type              |
>  Modifiers
>  gid        | integer                       | not null default
> nextval('"3dfloor_gid_seq"'::regclass)
>  newfeat_id | integer                       |
>  geom       | geometry(MultiPolygonZ,7415) |
> Indexes:
>     "3dfloor_pkey" PRIMARY KEY, btree (gid)
>     "3dfloor_geom_idx" gist (geom gist_geometry_ops_nd)
> The index has been created with ND support. Now, the table contains 16
> rows with varying Z values,
> sample summary here:
> > select gid, ST_ZMin(geom), ST_ZMax(geom) from "3dfloor";
>  gid | st_zmin | st_zmax
>    1 |       0 |       0
>    2 |       0 |       0
>    3 |       3 |       3
>    4 |       6 |       6
>    5 |       9 |       9
>    6 |      12 |      12
>    7 |      15 |      15
>    8 |      18 |      18
>    9 |      21 |      21
>   10 |      24 |      24
>   11 |      27 |      27
>   12 |      30 |      30
>   13 |      33 |      33
>   14 |      36 |      36
>   15 |      39 |      39
>   16 |      42 |      42
> I'm trying to filter using a 3d bbox, but I'm getting back all rows while
> I would expect to get only the first two, instead I'm getting
> back all of them:
> > select count(*) from "3dfloor" where geom &&&
> ST_3DMakeBox(ST_makePoint(0,0,0), ST_MakePoint(1000000,1000000,1));
> 16
> Anyone knows why it's happening? Hopefully I'm missing something obvious
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39  339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170118/507ff68f/attachment.html>
