[postgis-users] Understanding 3d bbox filtering support
Andrea Aime
andrea.aime at geo-solutions.it
Thu Jan 19 05:14:59 PST 2017
On Wed, Jan 18, 2017 at 5:13 PM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> I can't test right now,
> but :
> - you have the same srid for object and bbox right?
Err... the box3d does not seem to have a srid, nor I could find a way to
assign one.
> - I remember Sandro discussing this case
I searched in postgis-users before sending and again now, but could not
find any.
I've now searched in postgis-devel and found a thread you started on the
topic instead:
http://osgeo-org.1560.x6.nabble.com/BOX3D-strange-behaviour-td5251231.html
So... it seems that the z gets dropped eh? I see a pull request to fix it
but it seems it has
been closed and the associated ticket marked as "wont' fix":
https://trac.osgeo.org/postgis/ticket/3466
Soo... should I do 2d filtering using && and then do the z filtering using
ST_Zmin/ST_ZMax?
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170119/ede2a167/attachment.html>
