[postgis-users] Understanding 3d bbox filtering support
Daniel Baston dbaston at gmail.com
Thu Jan 19 05:48:48 PST 2017
> So... it seems that the z gets dropped eh? I see a pull request to fix it
> but it seems it has
> been closed and the associated ticket marked as "wont' fix":
Well, I think the ticket is showing that the patch represented a change in
behavior and wouldn't be backported to 2.2.  It should work as expected in
the latest stable release.
Dan
On Thu, Jan 19, 2017 at 8:14 AM, Andrea Aime <andrea.aime at geo-solutions.it>
wrote:
> On Wed, Jan 18, 2017 at 5:13 PM, Rémi Cura <remi.cura at gmail.com> wrote:
>> Hey,
>> I can't test right now,
>> but :
>>  - you have the same srid for object and bbox right?
> Err... the box3d does not seem to have a srid, nor I could find a way to
> assign one.
>>  - I remember Sandro discussing this case
> I searched in postgis-users before sending and again now, but could not
> find any.
> I've now searched in postgis-devel and found a thread you started on the
> topic instead:
> http://osgeo-org.1560.x6.nabble.com/BOX3D-strange-behaviour-td5251231.html
> but it seems it has
> https://trac.osgeo.org/postgis/ticket/3466
> Soo... should I do 2d filtering using && and then do the z filtering using
> ST_Zmin/ST_ZMax?
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39  339 8844549 <+39%20339%20884%204549>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170119/fa874ba4/attachment.html>
