[postgis-users] compiling from source code
Regina Obe lr at pcorp.us
Sat Jul 8 16:40:33 PDT 2017
Sandeep,
Which version of PostGIS are you trying to build?  Your configure might be ending for another reason.  For example in PostGIS 2.4, I think we now have a dependency on pkg-config which older versions of PostGIS do not.  We'll sort this out before PostGIS release, but I think downside at moment, is the it fails if pkg-config is not installed.  I forget the exact error you get.
I looked around on net for the -V and from what I can tell, that error is harmless and is just part of the process of configure checking the capabilities of the gcc compile.
I checked my own config.log and see the same error
configure:2948: x86_64-w64-mingw32-gcc -V >&5
x86_64-w64-mingw32-gcc.exe: error: unrecognized command line option '-V'
x86_64-w64-mingw32-gcc.exe: fatal error: no input files
compilation terminated.
But my configure continues, works fine and in the end shows this:
configure:20134: result:
configure:20136: result:   PostGIS is now configured for x86_64-w64-mingw32
configure:20138: result:
configure:20140: result:  -------------- Compiler Info -------------
configure:20142: result:   C compiler:           x86_64-w64-mingw32-gcc -g -O2
configure:20144: result:   SQL preprocessor:     /mingw64/bin/cpp -traditional-cpp -w -P
configure:20146: result:
configure:20148: result:  -------------- Dependencies --------------
configure:20150: result:   GEOS config:          /projects/geos/rel-3.7.0devw64gcc48/bin/geos-config
configure:20152: result:   GEOS version:         3.7.0dev
configure:20155: result:   GDAL config:          /projects/gdal/rel-2.2.1w64gcc48/bin/gdal-config
configure:20157: result:   GDAL version:         2.2.1
configure:20161: result:   SFCGAL config:        /projects/CGAL/rel-sfcgal-1.3.0w64gcc48/bin/sfcgal-config
configure:20163: result:   SFCGAL version:       1.3.0
configure:20167: result:   PostgreSQL config:    /projects/postgresql/rel/pg9.4w64gcc48/bin/pg_config
configure:20169: result:   PostgreSQL version:   PostgreSQL 9.4.5
configure:20175: result:   PROJ4 version:        49
configure:20177: result:   Libxml2 config:       /projects/libxml/rel-libxml2-2.7.8w64gcc48/bin/xml2-config
configure:20179: result:   Libxml2 version:      2.7.8
configure:20181: result:   JSON-C support:       yes
configure:20183: result:   protobuf-c support:   yes
configure:20185: result:   PCRE support:         yes
configure:20187: result:   PostGIS debug level:  0
configure:20189: result:   Perl:                 /usr/bin/perl
configure:20191: result:
configure:20193: result:  --------------- Extensions ---------------
configure:20196: result:   PostGIS Raster:       enabled
configure:20204: result:   PostGIS Topology:     enabled
configure:20211: result:   SFCGAL support:       enabled
configure:20219: result:   Address Standardizer support:       enabled
configure:20225: result:
configure:20227: result:  -------- Documentation Generation --------
configure:20229: result:   xsltproc:             /projects/xsltproc/xsltproc
configure:20231: result:   xsl style sheets:     /projects/docbook/docbook-xsl-1.76.1
configure:20233: result:   dblatex:
configure:20235: result:   convert:              /c/Windows/System32/convert
configure:20237: result:   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
Do you get an output anything like this or does it just end after that terminated?
Thanks,
Regina
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Sandeep Gupta
Sent: Friday, July 07, 2017 8:36 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] compiling from source code
Autoconf was missing, so I went ahead install autoconf, automake, and libtool.
Tried recompiling.
sh autogen.sh outputs:
* Running /home/linuxbrew/.linuxbrew/bin/glibtoolize (2.4.6)
   OPTIONS = --force --copy --install
glibtoolize: putting auxiliary files in '.'.
glibtoolize: copying file './config.guess'
glibtoolize: copying file './config.sub'
glibtoolize: copying file './install-sh'
glibtoolize: copying file './ltmain.sh'
glibtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'macros'.
glibtoolize: copying file 'macros/libtool.m4'
glibtoolize: copying file 'macros/ltoptions.m4'
glibtoolize: copying file 'macros/ltsugar.m4'
glibtoolize: copying file 'macros/ltversion.m4'
glibtoolize: copying file 'macros/lt~obsolete.m4'
glibtoolize: Consider adding '-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
* Running /home/linuxbrew/.linuxbrew/bin/aclocal (1.15.1)
* Running /home/linuxbrew/.linuxbrew/bin/autoconf (2.69) ======================================
Now you are ready to run './configure'
This does not solve though. When I run ./configure same error appears with -V flag being the issue.
-sandeep
On Fri, Jul 7, 2017 at 6:33 PM, Regina Obe <lr at pcorp.us> wrote:
> Okay I just got an irc note from Even Roualt.  He is running Ubuntu
> 16.04 and gcc 5.4  and had no issue running
> sh autogen.sh
> ./configure
> So doesn't seem like it's a newer gcc issue unless if its 5.3 specific.
> I'm suspecting something with brew,  MacOS, or tool chain like autoconf.
> What does:
> autoconf --version
> Return?
> I get
> autoconf (GNU Autoconf) 2.69
> Copyright (C) 2012 Free Software Foundation, Inc.
> License GPLv3+/Autoconf: GNU GPL version 3 or later
> Thanks,
> Regina
> Sent: Friday, July 07, 2017 6:18 PM
> Hi Regina,
>  Here is the output for gcc -v (install gcc from linuxbrew, which port of brew package manager of macOS):
> Reading specs from
> /home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/lib/gcc/x86_64-unknown-lin
> ux-gnu/5.3.0/specs
> COLLECT_GCC=gcc
> COLLECT_LTO_WRAPPER=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/libexe
> c/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
> Target: x86_64-unknown-linux-gnu
> Configured with: ../configure
> --prefix=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0
> --enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5
> --with-gmp=/home/linuxbrew/.linuxbrew/opt/gmp
> --with-mpfr=/home/linuxbrew/.linuxbrew/opt/mpfr
> --with-mpc=/home/linuxbrew/.linuxbrew/opt/libmpc
> --with-isl=/home/linuxbrew/.linuxbrew/opt/isl --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --with-build-config=bootstrap-debug --disable-werror --with-pkgversion='Homebrew gcc 5.3.0'
> --with-bugurl=https://github.com/Homebrew/homebrew/issues
> --enable-plugin --disable-nls --disable-multilib Thread model: posix
> gcc version 5.3.0 (Homebrew gcc 5.3.0)
> Thanks.
> sandeep
> On Fri, Jul 7, 2017 at 5:52 PM, Regina Obe <lr at pcorp.us> wrote:
>> Steve and Sandeep,
>> Can you try gcc -v instead and let me know what that outputs?
>> I just checked our Debian PostGIS bot, and she's running gcc 5.2.1  and think she's running the newest of any of our bots . So I can 't rule out a newer gcc at fault here.
>> However if I do gcc -V, I get an error on her too, so that's not the issue here:
>> gcc: error: unrecognized command line option  ?~-V ?T
>> gcc: fatal error: no input files
>> However, lower case -v  (which is what I think configure uses, works just fine).
>> gcc -v
>> outputs:
>> Using built-in specs.
>> COLLECT_GCC=gcc
>> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
>> Target: x86_64-linux-gnu
>> Configured with: ../src/configure -v --with-pkgversion='Debian
>> 5.2.1-22' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs
>> --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++
>> --prefix=/usr --program-suffix=-5 --enable-shared --ena
>> jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64
>> --with-arch-directory=amd64
>> --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc
>> --enable-multiarch --with-arch-32=i586 --with-abi=m64
>> --with-multilib-list=m32,m64,mx32 --enable-m Thread model: posix gcc
>> version 5.2.1 20151010 (Debian 5.2.1-22)
>> I'm not sure where Sandeep's   gcc -V is coming from in configure, cause it looks like gcc -v works fine on his system too, but then somewhere down the line switches to upper case -V which is not a valid switch command even in lower gcc versions.
>> Thanks,
>> Regina
>> From: Stephen Woodbridge Date: Fri, Jul 7, 2017 at 2:09 PM
>> I get the same error running on Ubuntu 16.04 with:
>> $ gcc -V
>> gcc: error: unrecognized command line option  -V
>> Looks like the option should be --version $ gcc --version gcc (Ubuntu
>> 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 Copyright (C) 2015 Free
>> This is free software; see the source for copying conditions.  There
>> is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
>> -Steve
>> On 7/7/2017 1:51 PM, Sandeep Gupta wrote:
>> Hi,
>> I am using gcc version 5.3 to compile postgis on Fedora.
>> The compile  fails at the configure step.
>> I get the error:
>> configure: error: C preprocessor "gcc" fails sanity check See
>> `config.log' for more details
>> The relevant line in config.log:
>> configure:3031: gcc -v >&5
>> Reading specs from
>> n
>> ux-gnu/5.3.0/specs
>> COLLECT_GCC=gcc
>> e c/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
>> configure:3042: $? = 0
>> configure:3031: gcc -V >&5
>> gcc: error: unrecognized command line option '-V'
>> It seems gcc does not like "-V" option. I this a issue to with later
>> gcc versions?
>> Thanks.
>> sandeep
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> This email has been checked for viruses by Avast antivirus software.
>> https://www.avast.com/antivirus
