[postgis-users] compiling from source code
Sandeep Gupta
gupta.sandeep at gmail.com
Mon Jul 10 11:11:57 PDT 2017
Hi Regina,
I tried several version of postgis (2.3.3, 2.4.0dev, 2.1.8). I have
pkg_config installed on my system.
The error I get is:
checking how to run the C preprocessor... gcc
configure: error: in `/home/sandeep/.cache/Homebrew/postgis-2.3.3':
configure: error: C preprocessor "gcc" fails sanity check
The configure doesn't proceed after this in my case.
Is there any temporary workaround that you suggest I can try?
Thanks.
sandeep
On Sat, Jul 8, 2017 at 7:40 PM, Regina Obe <lr at pcorp.us> wrote:
> Sandeep,
> Which version of PostGIS are you trying to build? Your configure might be ending for another reason. For example in PostGIS 2.4, I think we now have a dependency on pkg-config which older versions of PostGIS do not. We'll sort this out before PostGIS release, but I think downside at moment, is the it fails if pkg-config is not installed. I forget the exact error you get.
> I looked around on net for the -V and from what I can tell, that error is harmless and is just part of the process of configure checking the capabilities of the gcc compile.
> I checked my own config.log and see the same error
> configure:2948: x86_64-w64-mingw32-gcc -V >&5
> x86_64-w64-mingw32-gcc.exe: error: unrecognized command line option '-V'
> x86_64-w64-mingw32-gcc.exe: fatal error: no input files
> compilation terminated.
> But my configure continues, works fine and in the end shows this:
> configure:20134: result:
> configure:20136: result: PostGIS is now configured for x86_64-w64-mingw32
> configure:20138: result:
> configure:20140: result: -------------- Compiler Info -------------
> configure:20142: result: C compiler: x86_64-w64-mingw32-gcc -g -O2
> configure:20144: result: SQL preprocessor: /mingw64/bin/cpp -traditional-cpp -w -P
> configure:20146: result:
> configure:20148: result: -------------- Dependencies --------------
> configure:20150: result: GEOS config: /projects/geos/rel-3.7.0devw64gcc48/bin/geos-config
> configure:20152: result: GEOS version: 3.7.0dev
> configure:20155: result: GDAL config: /projects/gdal/rel-2.2.1w64gcc48/bin/gdal-config
> configure:20157: result: GDAL version: 2.2.1
> configure:20161: result: SFCGAL config: /projects/CGAL/rel-sfcgal-1.3.0w64gcc48/bin/sfcgal-config
> configure:20163: result: SFCGAL version: 1.3.0
> configure:20167: result: PostgreSQL config: /projects/postgresql/rel/pg9.4w64gcc48/bin/pg_config
> configure:20169: result: PostgreSQL version: PostgreSQL 9.4.5
> configure:20175: result: PROJ4 version: 49
> configure:20177: result: Libxml2 config: /projects/libxml/rel-libxml2-2.7.8w64gcc48/bin/xml2-config
> configure:20179: result: Libxml2 version: 2.7.8
> configure:20181: result: JSON-C support: yes
> configure:20183: result: protobuf-c support: yes
> configure:20185: result: PCRE support: yes
> configure:20187: result: PostGIS debug level: 0
> configure:20189: result: Perl: /usr/bin/perl
> configure:20191: result:
> configure:20193: result: --------------- Extensions ---------------
> configure:20196: result: PostGIS Raster: enabled
> configure:20204: result: PostGIS Topology: enabled
> configure:20211: result: SFCGAL support: enabled
> configure:20219: result: Address Standardizer support: enabled
> configure:20225: result:
> configure:20227: result: -------- Documentation Generation --------
> configure:20229: result: xsltproc: /projects/xsltproc/xsltproc
> configure:20231: result: xsl style sheets: /projects/docbook/docbook-xsl-1.76.1
> configure:20233: result: dblatex:
> configure:20235: result: convert: /c/Windows/System32/convert
> configure:20237: result: mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> Do you get an output anything like this or does it just end after that terminated?
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Sandeep Gupta
> Sent: Friday, July 07, 2017 8:36 PM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] compiling from source code
> Autoconf was missing, so I went ahead install autoconf, automake, and libtool.
> Tried recompiling.
> sh autogen.sh outputs:
> * Running /home/linuxbrew/.linuxbrew/bin/glibtoolize (2.4.6)
> OPTIONS = --force --copy --install
> glibtoolize: putting auxiliary files in '.'.
> glibtoolize: copying file './config.guess'
> glibtoolize: copying file './config.sub'
> glibtoolize: copying file './install-sh'
> glibtoolize: copying file './ltmain.sh'
> glibtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'macros'.
> glibtoolize: copying file 'macros/libtool.m4'
> glibtoolize: copying file 'macros/ltoptions.m4'
> glibtoolize: copying file 'macros/ltsugar.m4'
> glibtoolize: copying file 'macros/ltversion.m4'
> glibtoolize: copying file 'macros/lt~obsolete.m4'
> glibtoolize: Consider adding '-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
> * Running /home/linuxbrew/.linuxbrew/bin/aclocal (1.15.1)
> * Running /home/linuxbrew/.linuxbrew/bin/autoconf (2.69) ======================================
> Now you are ready to run './configure'
> This does not solve though. When I run ./configure same error appears with -V flag being the issue.
> -sandeep
> On Fri, Jul 7, 2017 at 6:33 PM, Regina Obe <lr at pcorp.us> wrote:
>> Okay I just got an irc note from Even Roualt. He is running Ubuntu
>> 16.04 and gcc 5.4 and had no issue running
>> sh autogen.sh
>> ./configure
>> So doesn't seem like it's a newer gcc issue unless if its 5.3 specific.
>> I'm suspecting something with brew, MacOS, or tool chain like autoconf.
>> What does:
>> autoconf --version
>> Return?
>> I get
>> autoconf (GNU Autoconf) 2.69
>> Copyright (C) 2012 Free Software Foundation, Inc.
>> License GPLv3+/Autoconf: GNU GPL version 3 or later
>> Thanks,
>> Regina
>> Sent: Friday, July 07, 2017 6:18 PM
>> Hi Regina,
>> Here is the output for gcc -v (install gcc from linuxbrew, which port of brew package manager of macOS):
>> Reading specs from
>> /home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/lib/gcc/x86_64-unknown-lin
>> ux-gnu/5.3.0/specs
>> COLLECT_GCC=gcc
>> COLLECT_LTO_WRAPPER=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/libexe
>> c/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
>> Target: x86_64-unknown-linux-gnu
>> Configured with: ../configure
>> --prefix=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0
>> --enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5
>> --with-gmp=/home/linuxbrew/.linuxbrew/opt/gmp
>> --with-mpfr=/home/linuxbrew/.linuxbrew/opt/mpfr
>> --with-mpc=/home/linuxbrew/.linuxbrew/opt/libmpc
>> --with-isl=/home/linuxbrew/.linuxbrew/opt/isl --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --with-build-config=bootstrap-debug --disable-werror --with-pkgversion='Homebrew gcc 5.3.0'
>> --with-bugurl=https://github.com/Homebrew/homebrew/issues
>> --enable-plugin --disable-nls --disable-multilib Thread model: posix
>> gcc version 5.3.0 (Homebrew gcc 5.3.0)
>> Thanks.
>> sandeep
>> On Fri, Jul 7, 2017 at 5:52 PM, Regina Obe <lr at pcorp.us> wrote:
>>> Steve and Sandeep,
>>> Can you try gcc -v instead and let me know what that outputs?
>>> I just checked our Debian PostGIS bot, and she's running gcc 5.2.1 and think she's running the newest of any of our bots . So I can 't rule out a newer gcc at fault here.
>>> However if I do gcc -V, I get an error on her too, so that's not the issue here:
>>> gcc: error: unrecognized command line option ?~-V ?T
>>> gcc: fatal error: no input files
>>> However, lower case -v (which is what I think configure uses, works just fine).
>>> gcc -v
>>> outputs:
>>> Using built-in specs.
>>> COLLECT_GCC=gcc
>>> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
>>> Target: x86_64-linux-gnu
>>> Configured with: ../src/configure -v --with-pkgversion='Debian
>>> 5.2.1-22' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs
>>> --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++
>>> --prefix=/usr --program-suffix=-5 --enable-shared --ena
>>> jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64
>>> --with-arch-directory=amd64
>>> --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc
>>> --enable-multiarch --with-arch-32=i586 --with-abi=m64
>>> --with-multilib-list=m32,m64,mx32 --enable-m Thread model: posix gcc
>>> version 5.2.1 20151010 (Debian 5.2.1-22)
>>> I'm not sure where Sandeep's gcc -V is coming from in configure, cause it looks like gcc -v works fine on his system too, but then somewhere down the line switches to upper case -V which is not a valid switch command even in lower gcc versions.
>>> Thanks,
>>> Regina
>>> From: Stephen Woodbridge Date: Fri, Jul 7, 2017 at 2:09 PM
>>> I get the same error running on Ubuntu 16.04 with:
>>> $ gcc -V
>>> gcc: error: unrecognized command line option -V
>>> Looks like the option should be --version $ gcc --version gcc (Ubuntu
>>> 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 Copyright (C) 2015 Free
>>> This is free software; see the source for copying conditions. There
>>> is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
>>> -Steve
>>> On 7/7/2017 1:51 PM, Sandeep Gupta wrote:
>>> Hi,
>>> I am using gcc version 5.3 to compile postgis on Fedora.
>>> The compile fails at the configure step.
>>> I get the error:
>>> configure: error: C preprocessor "gcc" fails sanity check See
>>> `config.log' for more details
>>> The relevant line in config.log:
>>> configure:3031: gcc -v >&5
>>> Reading specs from
>>> n
>>> ux-gnu/5.3.0/specs
>>> COLLECT_GCC=gcc
>>> e c/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
>>> configure:3042: $? = 0
>>> configure:3031: gcc -V >&5
>>> gcc: error: unrecognized command line option '-V'
>>> It seems gcc does not like "-V" option. I this a issue to with later
>>> gcc versions?
>>> Thanks.
>>> sandeep
>>> postgis-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>> This email has been checked for viruses by Avast antivirus software.
>>> https://www.avast.com/antivirus
