[postgis-users] ST_X does not exist in an update statement
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Jul 18 07:21:27 PDT 2017
Hi Giuseppe,
Thanks a lot for your reply.
Using lower case st_x was ok.... ST_X was not working in the update
statement.
That sounds quite weird to me.
Thanks a lot for the explanation, it does bring explanation!
Cheers,
Denis
Le mar. 18 juil. 2017 à 15:53, Giuseppe Broccolo <g.broccolo.7 at gmail.com> a
écrit :
> Hi Denis,
> 2017-07-18 11:51 GMT+02:00 Denis Rouzaud <denis.rouzaud at gmail.com>:
>> Hi all,
>> I'm bumbing my head against the wall.
>> I have an error "function st_x(geometry) does not exist" in an update
>> statement which I don't understand. If I copy the same exact line in a
>> select statement I get no error...
>> Here is the update statement:
>> update qwat_od.network_element set
>> label_1_x =
>> ST_X(ST_GeomFromEWKB(ST_Fineltra(ST_SetSRID(ST_MakePoint(label_1_x,label_1_y),21781),
>> 'chenyx06.chenyx06_triangles', 'the_geom_lv03', 'the_geom_lv95')))
>> where label_1_x is not null;
>> and the select statement:
>> select
>> from qwat_od.network_element
>> How come that the select succees while not the update???
> It looks like you are out of scope during the update execution, I mean, it
> looks like the update is not able to identify the schema where PostGIS
> functions and operators are defined. If this is the case, you could try to
> fully-qualify the function during its execution
> set label_1_x =
> <schema>.ST_X(<schema>.ST_GeomFromEWKB(<schema>.ST_Fineltra(<schema>.ST_SetSRID(<schema>.ST_MakePoint(label_1_x,label_1_y),21781),
> where <schema> is the name of the schema where PostGIS functions are
> defined - note, you probably need to fully-qualify the rest of the
> functions.
> You can check the schema through the psql command \df.
> Hope this help,
> Giuseppe.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170718/abc12824/attachment.html>
