[postgis-users] Postgis Polygon to Google Maps Polygon
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jun 1 17:04:37 PDT 2017
Does this sound like your problem:
https://gis.stackexchange.com/questions/97966/invalid-kml-representation-on-st-geomfromkml
Also look here:
https://trac.osgeo.org/postgis/search?q=kml&noquickjump=1&ticket=on
Can you try using a new version of Postgis?
Or try posting the how output of something like:
select geom from mytable where gid=<geom_that_fails>;
And someone here can try it on 2.x version for you.
-Steve
On 6/1/2017 6:14 PM, juancotrina wrote:
> Hi Tom for yor answer. I don't want to simplify any polygon. My porpose
> is export all vertice from spatial table (postgis) to kml, but using
> ST_AsKml only export some points, therefore it does not allow drawing
> the polygon completely into Google Earh.
> I using Postgis 1.3.5.
> Juan
> On Thu, Jun 1, 2017 at 2:55 PM, Tom van Tilburg-2 [via PostGIS] <[hidden
> email] </user/SendEmail.jtp?type=node&node=5011240&i=0>> wrote:
> Hi Juan,
> I'm not sure I understand your question. Do you mean that you want
> to simplify the polygon so it has less points? In that case, use
> ST_Simplify before your ST_AsKml function.
> Read more about it over here:
> https://postgis.net/docs/ST_Simplify.html
> <https://postgis.net/docs/ST_Simplify.html>
> Best,
> Tom
> On Thu, Jun 1, 2017 at 9:50 PM, juancotrina <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5011239&i=0>> wrote:
> Hi everybody:
> I want to export a polygon from postgis with lots of vertice to
> kml using
> FUNCTION st_askml, but no export all points. How can I solve
> this problem?,
> Thanks to help me.
> Juan Cotrina.
> http://postgis.17.x6.nabble.com/Postgis-Polygon-to-Google-Maps-Polygon-tp4470594p5011238.html
> <http://postgis.17.x6.nabble.com/Postgis-Polygon-to-Google-Maps-Polygon-tp4470594p5011238.html>
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5011239&i=1>
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> <https://lists.osgeo.org/mailman/listinfo/postgis-users>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5011239&i=2>
> If you reply to this email, your message will be added to the
> discussion below:
> http://postgis.17.x6.nabble.com/Postgis-Polygon-to-Google-Maps-Polygon-tp4470594p5011239.html
> <http://postgis.17.x6.nabble.com/Postgis-Polygon-to-Google-Maps-Polygon-tp4470594p5011239.html>
> To unsubscribe from Postgis Polygon to Google Maps Polygon, click here.
> NAML
> <http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Postgis Polygon to Google Maps Polygon
> <http://postgis.17.x6.nabble.com/Postgis-Polygon-to-Google-Maps-Polygon-tp4470594p5011240.html>
> <http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html> at Nabble.com.
> postgis-users at lists.osgeo.org
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
