[postgis-users] Cost weighted distance raster
    Spencer Gardner
    spencergardner at gmail.com
    Tue Mar  7 08:16:01 PST 2017
On Tue, Mar 7, 2017 at 7:07 AM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
wrote:
> Hi Spencer,
> Integrating something in the main PostGIS core is hard work. That’s why I
> started the PostGIS Addons: to quickly gather PLpgSQL-only functions into
> an easy to install .SQL file. Why I did not integrate those functions in
> the Addons yet? Lack of time, not much work involving PostGIS since a
> while, not sure the code is working properly.
> Did you get time to test it? If it work fine, I might take time to add it
> to the Addons before FOSS4G 2017.
> Pierre
That makes sense. I don't see a master .sql file to use for adding the
functions to the database. The GSOC proposal I linked to previously has
code for the Euclidean Distance function, but not for the Cost-Weighted
Distance function. Is there a single .sql file somewhere that I can use to
create both functions? I'd love to take a look and see if I can get them
both working.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170307/11857c53/attachment.html>
