[postgis-users] DISTINCT geometry to a code
Lars Aksel Opsahl
Lars.Opsahl at nibio.no
Wed Mar 15 09:32:13 PDT 2017
Hi
You can do something like this, but this uses a extra help table so it's not the best solution.
create table geo_key_map as ( select distinct md5(ST_asBinary(geo)) from test_table);
SELECT 8144241
Then you get a table where you add serial column and get counter from 1 to 8144241.
If you want you can wrap the code in to a function returning id based on md5 or insert a new md5 if it's missing. Using a own function will slow down response, but the md5 function is very fast.
The original table in this case contained 8144267 rows.
Lars
Fra: postgis-users <postgis-users-bounces at lists.osgeo.org> på vegne av juli g. pausas <juli.g.pausas at uv.es>
Sendt: 15. mars 2017 15:49
Til: PostGIS Users Discussion
Emne: [postgis-users] DISTINCT geometry to a code
Hi
I have a table with 945361 rows but the geometry (points) are distinct for 201606 locations (i.e., some rows refer to the same point in the space).
SELECT count(*) FROM juli.savannaswdsp; -- 945361
SELECT count(DISTINCT geom) FROM juli.savannaswdsp; -- 201606
Would it be possible to generate a column with codes for the points? that is, like an ID for each point instead for each row (e.g., from 1 to 201606), so rows with the same geom have the same code.
[ In R language this would be as follows: as.numeric(as.factor(geom)) ]
Thank for any suggestion
Juli
CIDE, CSIC | www.uv.es/jgpausas<http://www.uv.es/jgpausas> | blog<http://jgpausas.blogs.uv.es/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170315/2e5618d0/attachment.html>
