[postgis-users] DISTINCT geometry to a code
Nicolas Ribot
nicolas.ribot at gmail.com
Wed Mar 15 09:42:49 PDT 2017
You could use a windows function to generate ids for the points:
SELECT geom, row_number() over () as code
FROM juli.savannaswdsp
group by geom;
Nicolas
On 15 March 2017 at 15:49, juli g. pausas <juli.g.pausas at uv.es> wrote:
> Hi
> I have a table with 945361 rows but the geometry (points) are distinct for
> 201606 locations (i.e., some rows refer to the same point in the space).
> SELECT count(*) FROM juli.savannaswdsp; -- 945361
> SELECT count(DISTINCT geom) FROM juli.savannaswdsp; -- 201606
> Would it be possible to generate a column with codes for the points? that
> is, like an ID for each point instead for each row (e.g., from 1 to
> 201606), so rows with the same geom have the same code.
> [ In R language this would be as follows: as.numeric(as.factor(geom)) ]
> Thank for any suggestion
> Juli
> *CIDE, CSIC* | www.uv.es/jgpausas | blog
> <http://jgpausas.blogs.uv.es/>
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170315/bc758888/attachment.html>
