[postgis-users] DISTINCT geometry to a code
juli g. pausas juli.g.pausas at uv.es
Wed Mar 15 11:40:27 PDT 2017
Thanks Lars and Nicolas,
The windows option is simple and do exactly what I wanted. thanks.
Juli
*CIDE, CSIC*  |  www.uv.es/jgpausas  |  blog <http://jgpausas.blogs.uv.es/>
On Wed, Mar 15, 2017 at 5:42 PM, Nicolas Ribot <nicolas.ribot at gmail.com>
wrote:
> Hi,
> You could use a windows function to generate ids for the points:
> SELECT  geom, row_number() over () as code
> FROM juli.savannaswdsp
> group by geom;
> Nicolas
> On 15 March 2017 at 15:49, juli g. pausas <juli.g.pausas at uv.es> wrote:
>> Hi
>> I have a table with 945361 rows but the geometry (points) are distinct
>> for 201606 locations (i.e., some rows refer to the same point in the space).
>> SELECT count(*) FROM juli.savannaswdsp;                           --
>> 945361
>> SELECT  count(DISTINCT geom) FROM juli.savannaswdsp;   -- 201606
>> Would it be possible to generate a column with codes for the points? that
>> is, like an ID for each point instead for each row (e.g., from 1 to
>> 201606), so rows with the same geom have the same code.
>> [ In R language this would be as follows: as.numeric(as.factor(geom))  ]
>> Thank for any suggestion
>> Juli
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170315/a4235b06/attachment.html>
