[postgis-users] Efficient Way To Get Voronoi Polygons and Matched Points
Gerard LYNCH
gerard.lynch at ericsson.com
Tue Mar 21 22:35:28 PDT 2017
Hi Tom,
The d3 library is exactly what I needed. Although d3v4 removed the polygon clipping function, so I am using d3v3.
Cheers,
Gerard
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Tom van Tilburg
Sent: 07 March, 2017 8:14 AM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Efficient Way To Get Voronoi Polygons and Matched Points
Hi Gerard,
Considering that your points will always be in the heart of your polygons, an ST_Intersects would be faster than ST_Within. 1000 points x 1000 polygons should not be a problem at all in this matter, but you might consider adding a spatial index to the polygons.
On a side note: if your GUI is a web-site, you may consider using D3 voronoi: https://github.com/d3/d3-voronoi It does exactly what you describe.
Best,
Tom
On Thu, 2 Mar 2017 at 04:28 Gerard LYNCH <gerard.lynch at ericsson.com<mailto:gerard.lynch at ericsson.com>> wrote:
Hello,
I'm using postgis2.3 and ST_VoronoiPolygons.
I would like to know the best way to do a reverse lookup of sorts to find out which Voronoi polygon maps to which point(s) used in ST_Collect.
Currently I'm looping through each of the input points and doing a ST_Within on each of the Voronoi polygons until I get a match. This can be time consuming when there are 1000 points and 1000 voronoi polygons. I could also do the reverse and loop through each of the Voronoi polygons and fetch points within the polygon but I am wondering if there is a more efficient approach.
Ideally an object that returned something like "Polygon1 => [pointa, pointb], Polygon2 => [pointc]" etc would be preferable.
My use case is when someone clicks on a Voronoi polygon in my GUI I would like to be able to provide the user with information on the points used to create that polygon.
Cheers,
Gerard
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170322/82252d1c/attachment.html>
