[postgis-users] Loading geometrys from csv
Regina Obe lr at pcorp.us
Sun May 7 03:17:49 PDT 2017
Oops typo meant:
ALTER TABLE public.test ALTER COLUMN geom TYPE geometry USING ST_GeomFromWKB(geom);
As Mark mentioned (if bytea doesn't work try text for column type).
-----Original Message-----
Sent: Sunday, May 07, 2017 5:57 AM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: RE: [postgis-users] Loading geometrys from csv
That looks like WKB format.
What you could try is:
Change your geometry column in public.test to bytea
And then after you are done loading
ALTER TABLE public.test ALTER COLUMN geom TYPE geometry USING ST_GeomFromWB(geom);
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of John K
Sent: Friday, May 05, 2017 8:18 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Loading geometrys from csv
Hello,
I have a .csv file with a geometry, and I'm trying to load into a table.
copy public.test FROM '/home/john/test.csv' with (FORMAT csv, DELIMITER E',' )
The csv file has 4 columns and looks like:
1,113,31200,\x010600000001000000010300000001000000ba0a00008717...
I'm getting an error:
ERROR:  parse error - invalid geometry
HINT:  "\x" <-- parse error at position 2 within geometry
CONTEXT:  COPY test, line 2, column geom:
"\x01060000000100000001030000000100000042050000ac1c5a643b4d55c0333674b33f3c40401daa29c93a4d55c0333674..."
Is there anything obvious I'm doing wrong?
Thanks in advance,
John
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
