[postgis-users] Calculating area / length of a geometry in openstreetmap(osm) x, y coordinates at a given zoomlevel,
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Tue May 16 06:38:43 PDT 2017
World equator width is known in EPSG:3857 Mercator (delete/upgrade the
software that calls it 900913) and pixels at the zoom you're interested in.
I've got these in my .psqlrc, so that I can write ST_Buffer(geom, 20 *
:at_z12) to buffer something 20px at z12:
\set at_z12 38.22
\set at_z11 76.44
\set at_z10 152.87
\set at_z9 305.75
\set at_z8 611.5
\set at_z7 1222.99
\set at_z6 2445.98
\set at_z5 4891.97
\set at_z4 9783.94
\set at_z3 19567.88
\set at_z2 39135.76
\set at_z1 78271.52
\set at_z0 156543.04
сб, 13 мая 2017 г. в 2:59, Hemant Bist <hemantbist at gmail.com>:
> Hi,
> I want to figure out how big a geometry (line, polygon) is in osm map for
> a given zoomlevel. i.e. length of the line, area of the polygon.
> The data is stored in lan/lon coordinates (EPSG:4326). I know I can do
> something like st_area(st_transform(geometry, 900913)) to get the
> numbers in a other projections. But I am not sure if there is some magical
> projection number for each osm zoomlevel.
> I will appreciate any pointers for this.
> 1) I am not sure if there is a relation between area in 900913 projection
> and x,y coordinates for osm.
> 2) If someone has written some pl/sql or any other language utilities to
> do that, I can use them as well. I am not necessarily looking for an
> easy solution...
> 3) Here are actual functions that describe how to map the lat lon to x, y
> coordinates for a osm zoomlevel. If I remove the int rounding from the
> following osm link, I would get the x,y coordiantes for a given lat/lon for
> a given zoomlevel.
> http://wiki.openstreetmap.org/wiki/Slippy_map_tilenames#Python
> Best regards,
> Hemant Bist.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170516/d49b4f6d/attachment.html>
