[postgis-users] Problems creating postgis extension
Stephen Woodbridge
woodbri at swoodbridge.com
Tue May 30 12:34:26 PDT 2017
On 5/30/2017 3:22 PM, Martin Moore wrote:
> Thanks Steve – nothing returned.
> I’m guessing that’s wrong!
No it doesn't return anything. It just makes sure the library is known
to the dynamic loader. Hmm, I reread your message, you are missing a
symbol, so it found the library ok.
This sounds like a packaging issue of some kind. You should make sure
that you are getting proj4, postgresql and postgis all from the same
repository and not mixing and matching.
-Steve
> On 30/05/2017, 20:19, "postgis-users on behalf of Stephen Woodbridge" <postgis-users-bounces at lists.osgeo.org on behalf of woodbri at swoodbridge.com> wrote:
> Try:
> sudo ldconfig
> and see if the helps.
> -Steve
> On 5/30/2017 2:12 PM, Martin Moore wrote:
> > Hi,
> > On Debian Jessie 64bit, postgis 2.3, postgres 9.6 (both installed using
> > apt-get)
> > I can’t create postgis extension
> > psql -d mydb -c "CREATE EXTENSION postgis;"
> > ERROR: could not load library
> > "/usr/lib/postgresql/9.6/lib/postgis-2.3.so":
> > /usr/lib/postgresql/9.6/lib/postgis-2.3.so: undefined symbol:
> > pj_get_spheroid_defn
> > But it is there:
> > objdump -t -T /usr/lib/postgresql/9.6/lib/postgis-2.3.so | grep defn
> > 0000000000000000 DF *UND* 0000000000000000
> > It appears to have proj 4.8
> > ii libproj0 4.8.0-5
> > amd64 Cartographic projection library
> > ii proj-bin 4.8.0-5
> > amd64 Cartographic projection library (tools)
> > ii proj-data 4.8.0-5
> > amd64 Cartographic projection filter and library (datum
> > package)
> > I’m not a Linux guru and this has me stumped!
> > What am I missing?
> > Thanks,
> > Martin.
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
