[postgis-users] Getting started with PostGIS Raster
Regina Obe
lr at pcorp.us
Thu Nov 23 17:02:55 PST 2017
Brennan,
This workshop that came out recently is a pretty good primer for PostGIS
raster:
https://github.com/lcalisto/workshop-postgis-raster
Do you have postgis installed? If you do
CREATE EXTENSION postgis;
Will give you postgis raster functionality.
If you don't have it installed already - this page has some binary
installers for various OS and links to some instructions -
http://postgis.net/install/
Once you have PostGIS installed, and run CREATE EXTENSION postgis; in your
database.
Do
SELECT postgis_full_version();
You should see something like this: (note latest version is 2.4.2, I'm one
micro-behind
POSTGIS="2.4.1 r16012" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.2, released 2017/09/15"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
Once you have PostGIS installed, to load raster data in your database, use
raster2pgsql - covered here (depending on your OS, the raster2pgsql might be
in a separate package from the PostGIS server stuff)
http://postgis.net/docs/manual-2.4/using_raster_dataman.html#RT_Loading_Rast
ers
Hope that helps,
Regina
http://postgis.us
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Bell, Brennan Phillip
Sent: Thursday, November 23, 2017 4:43 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Getting started with PostGIS Raster
Greetings,
I am trying to set up the most recent version of PostGIS raster, and I am
looking for some help in getting started. I found the wiki links link below
helpful, but as I am not a postgresql expert, I have had some trouble
getting everything running:
http://trac.osgeo.org/postgis/wiki/UsersWikiInstall
Do you have a guide for getting the spatial DB set up, and populating it
with some data to help get me started?
Thanks,
Brennan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171123/b32216e2/attachment.html>
