[postgis-users] How can I update proj4 without recompile
Guido Stein
gstein at appgeo.com
Tue Nov 28 11:43:52 PST 2017
1)
Not totally sure.
I downloaded the gz, then did the following:
- unzipped the gz
- went into the folder
- ran ./configure
- ran make
- ran make install
And that is where I stop understanding what I am doing or how to test the
installation.
-guido
On Tue, Nov 28, 2017 at 1:44 PM Regina Obe <lr at pcorp.us> wrote:
> Guido,
> 1) Have you already installed proj 4.9? If so do you know what the
> libproj.so … is called?
> 2) Which faulty areas are you getting, you have an example of such a
> query. I fear that may be one of those bugs that is only fixable if
> PostGIS knows it is working with proj 4.9. Just want to rule that out.
> Thanks,
> Regina
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Guido Stein
> *Sent:* Tuesday, November 28, 2017 12:59 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] How can I update proj4 without recompile
> Hey folks,
> I am trying to update the proj4 libraries on my postgis because I think
> the older version of proj4 is giving me faulty areas (known bug). I would
> like to go from 4.8 to 4.9.
> In talking to some friends I found out that I can make a sym link from the
> existing proj4 to a newly compiled proj4 without an issue. But, I can't
> seem to figure that out completely and need a little help.
> # Here is what is running on my system:
> select version();
> PostgreSQL 9.5.10 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
> 4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit
> select postgis_full_version();
> POSTGIS="2.3.3 r15473"
> GEOS="3.4.2-CAPI-1.8.2 r3921"
> PROJ="Rel. 4.8.0, 6 March 2012"
> GDAL="GDAL 1.10.1, released 2013/08/26"
> LIBXML="2.9.1"
> LIBJSON="0.11.99"
> RASTER
> # here is what I have done so far:
> - locate the directory of the postgis
> pg_congif --pkglibdir
> - get information about what libraries are associated with postgis
> ldd postgis-2.3
> libproj.so.0 => /usr/lib/libproj.so.0 (0x00007ff19e1dd000)
> # this is where I loose the thread
> I don't know if when I make install if there should be a file I need to
> link here?? Yeah I need a clue and would be grateful for any assistance on
> this.
> -guido
> This e-mail message and any attachments may contain confidential or
> legally privileged information. If you are not an intended recipient or
> otherwise authorized to receive this message, you should not use, copy,
> distribute, disclose or take any action based on the information contained
> in this e-mail or any attachments. If you have received this message and
> material in error, please advise the sender immediately by reply e-mail and
> delete this message. Thank you on behalf of Applied Geographics, Inc.
> (AppGeo).
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
This e-mail message and any attachments may contain confidential or legally
privileged information. If you are not an intended recipient or otherwise
authorized to receive this message, you should not use, copy, distribute,
disclose or take any action based on the information contained in this
e-mail or any attachments. If you have received this message and material
in error, please advise the sender immediately by reply e-mail and delete
this message. Thank you on behalf of Applied Geographics, Inc. (AppGeo).
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171128/31e496f0/attachment.html>
