[postgis-users] Handling N-d arrays in PostGIS
Antonio Rodriges
antonio.rrz at gmail.com
Mon Oct 30 04:09:22 PDT 2017
Hello,
Thank you for the reply, however my data is slightly different. Sorry
that I did not make it clearer at the very beginning.
Actually I would like to import a dense, 3-d array of wind speed (a
time series of grids, each grid point contains the wind speed value)
The array is stored as a NetCDF file
FIles are here https://www.esrl.noaa.gov/psd/cgi-bin/db_search/DBListFiles.pl?did=61&tid=59909&vid=4298
The size of the array and its dimensions are below
dimensions:
lat = 94 ;
lon = 192 ;
time = 1460;
The array
short uwnd(time,lat,lon) ;
uwnd:long_name = "6-Hourly Forecast of U-wind at 10 m" ;
uwnd:valid_range = -32765s, -8765s ;
uwnd:unpacked_valid_range = -120.f, 120.f ;
uwnd:actual_range = -38.2f, 38.07f ;
uwnd:units = "m/s" ;
uwnd:add_offset = 207.65f ;
uwnd:scale_factor = 0.01f ;
uwnd:missing_value = 32766s ;
uwnd:_FillValue = -32767s ;
uwnd:precision = 2s ;
uwnd:least_significant_digit = 1s ;
uwnd:GRIB_id = 33s ;
uwnd:GRIB_name = "U GRD" ;
uwnd:var_desc = "u-wind" ;
uwnd:dataset = "NCEP/DOE AMIP-II Reanalysis (Reanalysis-2)" ;
uwnd:level_desc = "10 m" ;
uwnd:statistic = "Individual Obs" ;
uwnd:parent_stat = "Other" ;
uwnd:standard_name = "eastward_wind" ;
2017-10-30 11:04 GMT+03:00 Giuseppe Broccolo <g.broccolo.7 at gmail.com>:
> Hi Antonio,
> 2017-10-29 12:31 GMT+01:00 Antonio Rodriges <antonio.rrz at gmail.com>:
>> Hello,
>> Whether PostGIS allow importing 3-d, 4-d, etc. arrays or only 2-d arrays?
>> Specifically, I have a 3-d array with axes (time, lat, lon).
>> Does this mean that I need to split it onto 2-d bands (lat, lon) and
>> import the number of bands that is equal to the number of time steps
>> in the 3-d array?
> Which is the data source from which you import the data (e.g. textual,
> etc.)?
> If I've correctly understood, you have arrays where geospatial and
> non-geospatial information
> is present, each one providing a "dimension" of the array.
> Just FYI, in PostGIS is possible to define mixed, structured data with
> constructors like POINTM
> and POINT, that allow to add a further dimension to the 2D/3D (respectively)
> geospatial ones, that
> includes a scalar information.
> Hope this can help in your import, otherwise provide more information about
> source data and how
> you'd like to import.
> Giuseppe.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
