[postgis-users] Handling N-d arrays in PostGIS
Antonio Rodriges
antonio.rrz at gmail.com
Mon Oct 30 04:49:02 PDT 2017
Thank you for pointing to this tool.
However, I thought that since PostGIS uses GDAL it may be easier to import
such arrays, e.g. just split them onto individual 2-d grids (since PostGIS
mainly understands 2-d grids).
2017-10-30 14:34 GMT+03:00 Stephen V. Mather <svm at clevelandmetroparks.com>:
> I don’t know if it’s the ideal tool for the job, as it’s more flexible
> than you need, not being a regularized grid but a point cloud, but you
> might look to the pgPointCloud extension: https://github.com/
> pgpointcloud/pointcloud
> Cheers,
> Best,
> Steve
> [image: http://sig.cmparks.net/cmp-ms-90x122.png]*Stephen V. Mather*
> GIS Manager
> (216) 635-3243 (Work)
> (216) 339-6347 (Cell)
> --sent from phone--
> On Oct 30, 2017, at 07:09, Antonio Rodriges <antonio.rrz at gmail.com> wrote:
> Hello,
> Thank you for the reply, however my data is slightly different. Sorry
> that I did not make it clearer at the very beginning.
> Actually I would like to import a dense, 3-d array of wind speed (a
> time series of grids, each grid point contains the wind speed value)
> The array is stored as a NetCDF file
> FIles are here https://www.esrl.noaa.gov/psd/
> cgi-bin/db_search/DBListFiles.pl?did=61&tid=59909&vid=4298
> The size of the array and its dimensions are below
> dimensions:
> lat = 94 ;
> lon = 192 ;
> time = 1460;
> The array
> short uwnd(time,lat,lon) ;
> uwnd:long_name = "6-Hourly Forecast of U-wind at 10 m" ;
> uwnd:valid_range = -32765s, -8765s ;
> uwnd:unpacked_valid_range = -120.f, 120.f ;
> uwnd:actual_range = -38.2f, 38.07f ;
> uwnd:units = "m/s" ;
> uwnd:add_offset = 207.65f ;
> uwnd:scale_factor = 0.01f ;
> uwnd:missing_value = 32766s ;
> uwnd:_FillValue = -32767s ;
> uwnd:precision = 2s ;
> uwnd:least_significant_digit = 1s ;
> uwnd:GRIB_id = 33s ;
> uwnd:GRIB_name = "U GRD" ;
> uwnd:var_desc = "u-wind" ;
> uwnd:dataset = "NCEP/DOE AMIP-II Reanalysis (Reanalysis-2)" ;
> uwnd:level_desc = "10 m" ;
> uwnd:statistic = "Individual Obs" ;
> uwnd:parent_stat = "Other" ;
> uwnd:standard_name = "eastward_wind" ;
> 2017-10-30 11:04 GMT+03:00 Giuseppe Broccolo <g.broccolo.7 at gmail.com>:
> Hi Antonio,
> 2017-10-29 12:31 GMT+01:00 Antonio Rodriges <antonio.rrz at gmail.com>:
> Hello,
> Whether PostGIS allow importing 3-d, 4-d, etc. arrays or only 2-d arrays?
> Specifically, I have a 3-d array with axes (time, lat, lon).
> Does this mean that I need to split it onto 2-d bands (lat, lon) and
> import the number of bands that is equal to the number of time steps
> in the 3-d array?
> Which is the data source from which you import the data (e.g. textual,
> etc.)?
> If I've correctly understood, you have arrays where geospatial and
> non-geospatial information
> is present, each one providing a "dimension" of the array.
> Just FYI, in PostGIS is possible to define mixed, structured data with
> constructors like POINTM
> and POINT, that allow to add a further dimension to the 2D/3D
> (respectively)
> geospatial ones, that
> includes a scalar information.
> Hope this can help in your import, otherwise provide more information about
> source data and how
> you'd like to import.
> Giuseppe.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171030/76d58bc6/attachment.html>
