[postgis-users] Handling N-d arrays in PostGIS
Stephen V. Mather svm at clevelandmetroparks.com
Mon Oct 30 04:52:17 PDT 2017
Ya, I’m not sure point clouds are at all the fix. They just address the dimensionality question well, though not the gridded data requirement.
Cheers,
Best,
Steve
[http://sig.cmparks.net/cmp-ms-90x122.png]Stephen V. Mather
GIS Manager
(216) 635-3243<tel:(216)%20635-3243> (Work)
(216) 339-6347 (Cell)
--sent from phone--
On Oct 30, 2017, at 07:49, Antonio Rodriges <antonio.rrz at gmail.com<mailto:antonio.rrz at gmail.com>> wrote:
Thank you for pointing to this tool.
However, I thought that since PostGIS uses GDAL it may be easier to import such arrays, e.g. just split them onto individual 2-d grids (since PostGIS mainly understands 2-d grids).
2017-10-30 14:34 GMT+03:00 Stephen V. Mather <svm at clevelandmetroparks.com<mailto:svm at clevelandmetroparks.com>>:
I don’t know if it’s the ideal tool for the job, as it’s more flexible than you need, not being a regularized grid but a point cloud, but you might look to the pgPointCloud extension: https://github.com/pgpointcloud/pointcloud
Cheers,
Best,
Steve
GIS Manager
--sent from phone--
On Oct 30, 2017, at 07:09, Antonio Rodriges <antonio.rrz at gmail.com<mailto:antonio.rrz at gmail.com>> wrote:
Hello,
Thank you for the reply, however my data is slightly different. Sorry
that I did not make it clearer at the very beginning.
Actually I would like to import a dense, 3-d array of wind speed (a
time series of grids, each grid point contains the wind speed value)
The array is stored as a NetCDF file
FIles are here https://www.esrl.noaa.gov/psd/cgi-bin/db_search/DBListFiles.pl?did=61&tid=59909&vid=4298
The size of the array and its dimensions are below
dimensions:
   lat = 94 ;
   lon = 192 ;
   time = 1460;
The array
short uwnd(time,lat,lon) ;
     uwnd:long_name = "6-Hourly Forecast of U-wind at 10 m" ;
     uwnd:valid_range = -32765s, -8765s ;
     uwnd:unpacked_valid_range = -120.f, 120.f ;
     uwnd:actual_range = -38.2f, 38.07f ;
     uwnd:units = "m/s" ;
     uwnd:add_offset = 207.65f ;
     uwnd:scale_factor = 0.01f ;
     uwnd:missing_value = 32766s ;
     uwnd:_FillValue = -32767s ;
     uwnd:precision = 2s ;
     uwnd:least_significant_digit = 1s ;
     uwnd:GRIB_id = 33s ;
     uwnd:GRIB_name = "U GRD" ;
     uwnd:var_desc = "u-wind" ;
     uwnd:dataset = "NCEP/DOE AMIP-II Reanalysis (Reanalysis-2)" ;
     uwnd:level_desc = "10 m" ;
     uwnd:statistic = "Individual Obs" ;
     uwnd:parent_stat = "Other" ;
     uwnd:standard_name = "eastward_wind" ;
2017-10-30 11:04 GMT+03:00 Giuseppe Broccolo <g.broccolo.7 at gmail.com<mailto:g.broccolo.7 at gmail.com>>:
Hi Antonio,
2017-10-29 12:31 GMT+01:00 Antonio Rodriges <antonio.rrz at gmail.com<mailto:antonio.rrz at gmail.com>>:
Hello,
Whether PostGIS allow importing 3-d, 4-d, etc. arrays or only 2-d arrays?
Specifically, I have a 3-d array with axes (time, lat, lon).
Does this mean that I need to split it onto 2-d bands (lat, lon) and
import the number of bands that is equal to the number of time steps
in the 3-d array?
Which is the data source from which you import the data (e.g. textual,
etc.)?
If I've correctly understood, you have arrays where geospatial and
non-geospatial information
is present, each one providing a "dimension" of the array.
Just FYI, in PostGIS is possible to define mixed, structured data with
constructors like POINTM
and POINT, that allow to add a further dimension to the 2D/3D (respectively)
geospatial ones, that
includes a scalar information.
Hope this can help in your import, otherwise provide more information about
source data and how
you'd like to import.
Giuseppe.
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171030/d167d3e3/attachment.html>
