[postgis-users] Postgres Timeouts
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Wed Apr 11 09:46:18 PDT 2018
alter system set statement_timeout to '5min';
Locally we use 6 hour timeout, so an evening started job would be finished,
or slaughtered, by morning.
ср, 11 апр. 2018 г. в 18:39, Aaron Edwards <aedwards at b3insight.com>:
> Hi,
> My ETL process requires that I issue several long-running queries to
> postgresql. Queries like building indexes, updating SRIDs, that kind of
> thing.
> My problem is that if the query takes too long to run, something over 5
> minutes (but I don’t know the actual number for certain), then the query
> never returns. I’ve set the ConnectionTimeout property of the connection
> to 0, which I understand is no timeout. But the command is timing out
> anyway. Often times I can see that the command has completed successfully,
> by looking for the presence of the objects the command is creating in pg
> Admin. But the script still hangs, because as far as it knows, postres is
> still processing it’s previous command.
> Is there a default timeout setting that is global to a postgresql database
> or server?
> Thanks.
> Aaron
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180411/fb1a636a/attachment.html>
