[postgis-users] Very long query time
Tumasgiu Rossini
rossini.t at gmail.com
Thu Dec 6 08:09:01 PST 2018
I do not really understand.
Is it a query which used to be faster ?
A little remark on your where clause :
it is unnecesseraly complicated and could be shortened to :
WHERE st_intersects(zi.geom, tile.geom)
True and false value doesn't need to be surronded by quote,
here you are implicitly casting the string value 'true' to its boolean
representation
Le jeu. 6 déc. 2018 à 16:53, Manchon Pierre <pierre.manchon at irstea.fr> a
écrit :
> Hello there,
> I'm new on the list and for a premiere I would like to know if some of you
> have a very long runtime for some of their queries (even with a LIMIT 5),
> whereas those queries were working well before (nothing changed from
> that). I'm using Postgre10, pgAdmin4 and postgis 2.4.4 on windows …
> The infinite query I’m trying to execute: (only ~500 rows are stored on
> each of the two tables)
> SELECT code_tile, code_zi FROM data.tile, data.zi
> WHERE ST_Intersects(zi.geom, tile.geom) = 'true'
> GROUP BY code_zi, code_tile, zi.geom, tile.geom
> LIMIT 5
> Thank you for your time
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181206/1ea6bdc4/attachment.html>
