[postgis-users] Compiling Postgis from source - gdal error
Paul Ramsey pramsey at cleverelephant.ca
Tue Dec 11 12:42:51 PST 2018
Reading through the configure routine, I see nothing that should be causing
those tests to fail now if they worked in the past... they are the same
code as in 2.5.0
On Tue, Dec 11, 2018 at 12:32 PM Bruce Rindahl <bruce.rindahl at gmail.com>
wrote:
> Response from 'which gdal-config'
> pi at pi3ch:~/postgis-2.5.0 $ which gdal-config
> /usr/local/bin/gdal-config
> pi at pi3ch:~/postgis-2.5.0 $ gdal-config --version
> 2.3.2
> pi at pi3B0:~/postgis-2.5.1 $ which gdal-config
> pi at pi3B0:~/postgis-2.5.1 $ gdal-config --version
> 2.3.2
> pi at pi3B0:~/postgis-3.0.0dev $ gdal-config --version
> 2.3.2
> pi at pi3B0:~/postgis-3.0.0dev $ which gdal-config
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181211/fdb05d0f/attachment.html>
