[postgis-users] drawing a line tangent to earth ?
didier peeters
dpeeter1 at ulb.ac.be
Mon Feb 5 07:08:32 PST 2018
Here’s the problem that puzzles me:
I would like to determine if an object (a building, an antenna, …) can be seen from a specific point ‘somewhere'. I have to deal with distances ranging from a few meters to about 200 km or so. I have the coordinates of the viewing point XYZ and the XYZ coordinates of the object to check as well as its height, and I should find what part of the object is viewable above the horizon, i.e. how many meters of it can be seen (considering that the earth is not flat … ) .
I thought of assimilating the earth to a trigonometric circle but I fear that the precision would not be good enough for evaluating the height of an antenna above the radius of the planet.
I’m working with Postgresql/postgis and would prefer to remain in this environment but could add some extensions or other languages functions.
Any suggestion welcome !
Didier
