[postgis-users] Database restarting while using ST Functions
Daniel Baston dbaston at gmail.com
Tue Feb 6 03:43:18 PST 2018
Hi Pradeep,
Try checking the output of "SELECT postgis_full_version()". If you're not
at the latest point-release, you should upgrade. There have been memory
handling bugs with ST_CollectionHomogenize that could maybe cause the issue
you're seeing.
Dan
On Tue, Feb 6, 2018 at 5:59 AM, Pradeep Kanth G <pgundala at avineonindia.com>
wrote:
> Dear All,
> Kindly raise the below issue with EDB.
> *Observation* :  Database restarting while using  ST Functions.
> *Issue* :   Intersecting with two geometries, while using ST_Intersects
> and ST_CollectionHomogenize functions
> Database is restarting automatically.
> *Example*: ST_Intersects(ST_CollectionHomogenize(p.geometry,c.geometry))
> *Screenshot:*
> Regards
> Pradeep Kanth
> *Disclaimer *| The information contained in this electronic message
> (including any attachments) is intended for the exclusive use of the
> addressee(s) and may contain confidential or privileged information.If you
> have received this in error, please notify the sender immediately and
> delete the material from your machine. Any  action including review,
> retransmission, dissemination of this email or the attachments present
> along with the email by persons or entities other than the intended
> recipient is prohibited.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180206/1a3958c8/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180206/1a3958c8/attachment.png>
